Broached currently, still looking at edm services.
Cnc service is the most streamlined/best cost from what I’ve seen
Broached will likely be the cheapest in the long run (after the cost of the broach is overcome).
Im interested. I probably need a different bolt pattern but I can make it work. Maybe later I can make my own and have that shop broach it for me.
I’m thinking of leaving out the bolt pattern, so it’ll be blank. So what ever pattern anyone wants they can mill it after the fact.
Also making it compatible with a variety of 1 1/2 bearings so you can connect a flywheel or drive shaft.
That's probably ideal. Any common machine shop should be able to do any desired pattern, but EDM or broaches are few and far between. Im in for one for sure with no bolt pattern on it.
Re: Leaf spline coupler
Posted: Wed Feb 26, 2020 8:37 am
by Mouse
How did you determine the profile of the splines?
I've got a Outlander rear motor here with a splined output and can't find anything that might fit the splined shaft.
Posted: Wed Mar 04, 2020 10:13 am
by zippy500
Hi
Any update on a group buy, I was looking the 3DHUBS site, even just buying two pieces the price drops considerably.
There is a mass of build materials to chose from, would just steel be strong enough for the spline.
does your part need to threaded on the fixing holes,
Can someone link the rotex hub this is designed for ?
Posted: Tue Mar 10, 2020 12:01 pm
by purplespark
I'd be interested in one !
Yup. Almost done the design. Putting together a universal system, adapter plate, with a angler thruster bearing. Besides just direct coupling to a transmission, you could set up a fly wheel or drive shaft as well.
Working to keep costs low and increase use case.
I’ll have updates very soon and do a bulk order of the coupler.
Posted: Tue Mar 24, 2020 11:27 pm
by purplespark
Hi ,
Any news ?
Posted: Wed Mar 25, 2020 4:06 am
by Bratitude
purplespark wrote: ↑Tue Mar 24, 2020 11:27 pm
Hi ,
Any news ?
Coupler and assembly design is now finished.
in a few days I’ll be sending out an order for 10 couplers, hopefully.
As I’m sure for many others here, life is a bit chaotic at the moment. So things are taking longer than usual.
Posted: Thu Mar 26, 2020 5:16 pm
by purplespark
Yes , of course , challenging times.
I shall wait patiently !
Posted: Wed May 06, 2020 7:11 pm
by bobby_come_lately
Mouse wrote: ↑Wed Feb 26, 2020 8:37 am
Sorry to jump on to an old thread but did you find a solution to this? I think I have Meiden motor with the same 3/4in shaft as your Outlander motor. Been searching for something that fits and just starting to muck around in CAD to see what an adaptor might cost.
Posted: Wed May 06, 2020 11:35 pm
by jerrykco
Bratitude wrote: ↑Wed Mar 25, 2020 4:06 am
Hey, Bratitude,
Can you publish the finished design pictures?
I need to connect the leaf to a drive shaft.
I'm interested seeing if your design will work for me.
Posted: Fri May 08, 2020 11:17 am
by DarkwingDuck
Hi Bratitude
I am also running a Leaf motor and have gone the usual route trying out different clutch plates (Daihatsu, Volvo etc..) to no avail. I am interested in trying out your solution when it becomes available
Posted: Fri May 08, 2020 4:46 pm
by celeron55
The ghetto Leaf coupler is a Blue Print ADC43101 clutch disc or similar. It fits a bunch of japanese and korean vehicles and is cheap.
It's a loose match and probably different spline profile, but I've been running it for almost 30 000 km in my minivan so far just fine. There is enough meat in the splines. I assume the quite soft motor shaft will adjust to the very hard clutch profile over time.
If anything, at least it's taking a whole lot of time for anyone to be able to tell me "I told you so". 8)
Hey, Bratitude,
Currently away, but couplers are on order.
Ill try to dig out the specs. Spent a good amount of time setting the coupler up to be fairly universal for most people’s needs
What I currently access to.
was ether a 3in or 2.75 di plate with centring marks that match the rotex gs38 bolt pattern.
couple will nest in an angler bearing, with renting clip. For those wishing to run a clutch or drive shaft.
Posted: Sun May 10, 2020 8:11 am
celeron55 wrote: ↑Fri May 08, 2020 4:46 pm
I smashed two blueprint Mazda center pieces couple of years back. It is not very hard too.
If I may suggest you put two center pieces in line and weld them in your coupler. That way it will definitely hold.
Torque is transfered along the shaft length...
Posted: Sun May 10, 2020 8:38 am
by Kevin Sharpe
Damien is using a Fiat Van clutch disc (watch from 2:35)
Is this the clutch plate?
Clutch Plate Fiat Ducato 2500 Turbo Diesel MK1 85-93 Clutch Disk?
