Page 1 of 2
GS450h RPM feedback always 0
Posted: Fri Jun 28, 2024 7:05 pm
by Bigpie
I've got the GS450h inverter/transmission setup in my BMW, with zombieverter, it's driving nice but the speed param is always 0. I added spot params for mg1 rpm and mg2 rpm and these are always 0.
I've attached a capture from a cheap logic analyser driving back and forward a little, if anyone could take a look who knows the sync serial protocol and identify if there rpms are in there or if they're 0?
Re: GS450h RPM feedback always 0
Posted: Sat Jun 29, 2024 3:00 am
by Zechy
Hi Jamie
The data seems to be corrupted.
With my cheap logic analyser, it only worked properly if I capture one channel at a time. MTH example below
Syncserial settings:
Posted: Sat Jun 29, 2024 9:16 am
by Bigpie
Logs.zip
(4.21 MiB) Downloaded 216 times
Are these any better?
Posted: Sat Jun 29, 2024 4:43 pm
by Bigpie
Separate.zip
(983.92 KiB) Downloaded 226 times
And separate
Posted: Sat Jun 29, 2024 5:13 pm
by Bigpie
My picoscope captures look better
Posted: Sun Jun 30, 2024 5:39 am
by Zechy
Bigpie wrote: Sat Jun 29, 2024 9:16 am Logs.zipAre these any better?
Still not looking good.
Do you connect MTH- to ground and MTH+ to channel 0 when capturing the data on the analyser?
Posted: Sun Jun 30, 2024 9:02 am
by Bigpie
Nope, I had ground to ground and mth+ to channel 0 :D will try that
Posted: Sun Jun 30, 2024 11:48 am
by Zechy
Bigpie wrote: Sat Jun 29, 2024 5:13 pm My picoscope captures look better
Sorry. I couldn't figure out how to decode picoscope data.
Posted: Sun Jun 30, 2024 11:53 am
by uhi22
Is somewhere an explanation how this communication works (on physical layer and logical layer)?
Posted: Sun Jun 30, 2024 11:58 am
by Zechy
uhi22 wrote: Sun Jun 30, 2024 11:53 am Is somewhere an explanation how this communication works (on physical layer and logical layer)?
There is some information here https://openinverter.org/wiki/Toyota_In ... e_Protocol
Posted: Sun Jun 30, 2024 12:31 pm
by Bigpie
These look a lot better.
Posted: Sun Jun 30, 2024 1:01 pm
by uhi22
Found this thread,
viewtopic.php?t=205
where they explain the physical layer. One conclusion is to use a CAN transceiver to convert the differential signals to logic level. Then we have 500kBaud async serial with the usual start-data-stop, which should be decodable with the Saleae software.
Posted: Sun Jun 30, 2024 1:27 pm
by Zechy
Bigpie wrote: Sun Jun 30, 2024 12:31 pm These look a lot better.
Looking good
I invert the signal
20240630_forJamie.xlsx
(16.64 MiB) Downloaded 220 times
Posted: Sun Jun 30, 2024 2:05 pm
by Zechy
To test if the speed is coming into the ZombieVerter correctly, try and write it to the temperature
by Bigpie
Is that spreadsheet using my data?
That seems to be working mostly, the bus voltage is about x2 what it should be
Posted: Sun Jun 30, 2024 2:09 pm
by Zechy
Bigpie wrote: Sun Jun 30, 2024 2:05 pm Is that spreadsheet using my data?
Yes that's your data.
Bus voltage gets divided by 2
Posted: Sun Jun 30, 2024 2:14 pm
by Bigpie
I've getting my invudc to be 117V in Zombie, which is around 1/3 of the value :S
Posted: Sun Jun 30, 2024 6:26 pm
by Bigpie
So it seems I have some sort of comms issue.
I've added a counter in as below
     if(VerifyMTHChecksum(100)==0 || dma_get_interrupt_flag(DMA1, DMA_CHANNEL6, DMA_TCIF)==0)
            statusInv=0;
        else
            //exchange data and prepare next HTM frame
            dma_clear_interrupt_flags(DMA1, DMA_CHANNEL6, DMA_TCIF);
            statusInv=1;
            dc_bus_voltage=(((mth_data[82]|mth_data[83]<<8)-5)/2);
            temp_inv_water=(mth_data[42]|mth_data[43]<<8);
            temp_inv_inductor=(mth_data[86]|mth_data[87]<<8);
            mg1_speed=mth_data[6]|mth_data[7]<<8;
            mg2_speed=mth_data[31]|mth_data[32]<<8;
            Param::SetInt(Param::mth6, mth_data[6]);
            Param::SetInt(Param::mth7, mth_data[7]);
            Param::SetInt(Param::mth5, mth_data[5]);
            Param::SetInt(Param::mth30, mth_data[30]);
            Param::SetInt(Param::mth31, mth_data[31]);
            Param::SetInt(Param::mth32, mth_data[32]);
            Param::SetInt(Param::mth33, mth_data[33]);
            Param::SetInt(Param::state4Counter, counter);
            if(counter>200)
                counter = 0;
            else
                counter++;
counter seems to work until I engage drive or reverse. The Sync serial lines wires are the OEM harness and not extended. Ive depinned them from zombie and checked the crimps. Checked the inverter grounding.
Posted: Mon Jul 01, 2024 8:16 am
by uhi22
To collect the things together I added some links to the different threads here: https://openinverter.org/wiki/Toyota_In ... a_Protocol
To understand what is happening on physical layer I propose to do the following measurements:
1. With osci ground connected to the VCU ground, measure the MTH+ and MTH-, using two osci channels. These should show zero difference in "recessive" mode (most of the time), and a clean difference during the "active" time. The above shown picture contains spikes which should not be there.
2. With osci ground connected to the VCU ground, measure inside the VCU what the receiver IC made from the differential signal. From the schematic https://github.com/damienmaguire/Stm32- ... ematic.pdf we see that a CAN transceiver is used to convert the differential signal coming on MTH+ and MTH-, to a logic level signal. The logic level side should show the clean serial signal.
Another question is regarding the message validity check. Does the VCU check the CRC of the incoming data, or does it just report what it got, even if it is garbage?
Posted: Mon Jul 01, 2024 9:05 am
by Bigpie
There is a checksum performed, as soon as I put the car in to Drive or Reverse the MTH gets messed up
 case 3:
            statusInv=0;
        else
            statusInv=1;
I'll do some probing.
Posted: Mon Jul 01, 2024 12:55 pm
by Bigpie
This is the MTH pairs with a 3rd calculated channel of B-A which seems to do a good job of eliminating the noise.
Posted: Mon Jul 01, 2024 2:52 pm
by Bigpie
And attached scope to the RX and CAN of the IC
Posted: Mon Jul 01, 2024 3:01 pm
by uhi22
Indeed, the difference and the digital level looks quite good.
Bigpie wrote: Mon Jul 01, 2024 9:05 am There is a checksum performed, as soon as I put the car in to Drive or Reverse the MTH gets messed up
Indeed, there is a checksum verification, and the code behind makes sense. Even there is a small chance, that totally corrupted data still has the right checksum, I would draw the conclusion: If the checksum is correct, then the data packet is valid. For me this looks like that the data format, which was found by reverse-engineering, is not always used. Maybe your GS450 uses a different format as soon as you are in drive or reverse. So basically starting from scratch, record the MTH data with a logic analyzer while changing the RPM and the voltage, and find which bytes are changing and what is the scaling. Maybe there is a "format identifier" at the beginning of the MTH data, which selects different message layouts.
Posted: Mon Jul 01, 2024 4:08 pm
uhi22 wrote: Mon Jul 01, 2024 3:01 pm checksum, I would draw the conclusion: If the checksum is correct, then the data packet is valid.
Why would this work for everyone so far? @Jamie please post the part number of your inverter.
From the findings so far it seems that the STM32 is saying the transfer does not complete.
387         if(VerifyMTHChecksum(100)==0 || dma_get_interrupt_flag(DMA1, DMA_CHANNEL6, DMA_TCIF)==0)
With the checksum check remove it still goes into this if statement to change InvState, thus there is a lower level issue. However reviewing the scope and serial data derived it is just the "standard" GS450h message packets.
Please keep in mind there are many other out there running various Toyota/Lexus inverter without any feedback of a similar issue that was not resolved with tidying wiring, 12V supply and grounds.
Posted: Mon Jul 01, 2024 4:18 pm
by uhi22
My interpretation of the code:
If checksum is wrong OR dma is not finished
THEN treat inverter data as "Not present"
ELSE take some physical values out of the 100 bytes received data.
So a wrong checksum would lead to stuck values, not to write bullshit into vdc etc.
Means: lowlevel data corruption would be detected and correctly handled from my PoV.
