Teardown: 275A/48V Sevcon motor controller Gen4 4827
janosch
Has thanked: 94 times
Been thanked: 81 times
Post by janosch »
Hello,
Not sure if someone has done these, so sharing this here.
I expected an H-Bridge and wanted to harvest the IGBTs, but found a MOSFET array instead.
I opened it up and found the following:
All glued together, one big heatsink at the bottom.
Form Factor: 19cm x 17cm x 7cm
Weight: 1.9kg
Haven't done any tracing or tried to boot it, these would be perfect for a Go-Kart or powerful E-Bike.
I hope this helps!
Edit: Ah, someone opened them in 2015 as well, with some images now 404d.
