[WIP] Citroen Saxo Electrique
Posted: Sun Mar 17, 2024 6:08 pm
Bought a Saxo electrique december of 2018 with a burned collector on the dc motor.
Original:
Over the last year I have bought all parts listed, connectors, pins and wire. At this moment I have the first version of the BMS pcb working on the E208 battery, the first version of the pcb with Openinverter running the XC90 controller and spinning the motor. Have a ZombieVerter VCU to control this mismatch of parts.
Currently designing the battery boxes. One in the back unter the car with 10 modules. It is a tight fit but I think it will fit. And one in the front with 8 modules.
Original:
- Motor: Leroy-somer SA-13 11kW (20kW max) separately excited dc motor
- Batteries: SAFT STM 5-100 nickel-cadmium 20x6V 120V nominal
- Controler: 200A dc with 11A for excitation
- Charger: 3kW (integrated in Controller)
- DCDC: 14.1V 70A (integrated in Controller)
- Heater: Webasto Thermo Top gasoline 5kW
- Power steering: electro hydraulic
- Power brakes: vacuumpomp with vacuum switch
- Motor: MES-dea AC induction 42kW (from a Peugeot Partner Venturi)
- Batteries: LEV-50 2p44s (from a Peugeot ION)
- Controler: MES-dea TIM600 (original controller bypassed)
- Charger: original (changed settings)
- DCDC: original
- Heater: original
- Power steering: original
- Power brakes: MES-dea vacuumpomp
- Motor: Volvo V60 phev 50Kw viewtopic.php?t=3859
- Batteries: Peugeot E208 battery pack 108S viewtopic.php?t=2465
- Controler: Volvo XC90 with Openinverter pcb/software viewtopic.php?t=3675
- Charger: Audi e-tron 11kw 3 phase (MG ZS 7.2kW backup plan)
- DCDC: Integrated in Controller (have this working at 13.5V possibly adjustable)
- Heater: Not sure maybe a leaf heater because I have one
- Power steering: Opel Corsa powered steering column
- Power brakes: i-booster form a Toyota Yaris
- Fast charging: 50kW CCS
