PTC Cabin Heater
Posted: Wed Jan 15, 2020 10:26 am
Hi all
I had asked a question about PC heaters in arber333's Hardware thread but decided to bring it out here so as not to clutter up the broader discussion over there. I was asking if anyone had used the 5kW heater from the Gen 1 Leaf (27143-7269RET) and plumbed it into their existing heater matrix like I have in the Audi 80. There is a schematic from damian.lo below and I found a bit of info at http://www.nissantechnicianinfo.mobi/ht ... ntrol.html about the control. There is LIN bus comms from the A/C auto amplifier but it's PWM. It's not my area of expertise but, does this make any sense as to the control element and if this is a usable PTC?
The PTC heater provides an internal control circuit and performs LIN communication with A/C auto amplifier. Based on the signals from A/C auto amplifier, the microcomputer inside PTC heater controls the heater output by PWM. When current is applied, it heats up. Upon reaching a certain temperature (Curie temperature) the resistance suddenly increases, limiting the current, and maintaining a constant amount of heating. Any ideas on how you would work giving it PWM signal from an early 90's VAG heater system?
