Prius boost module PM400DV1A120
MoonUnit
Has thanked: 11 times
Been thanked: 9 times
Post by MoonUnit »
Hello, does anyone have a datasheet or specification info on the boost control module in the Prius inverter/controller (gen 2) - part number PM400DV1A120?
I'm interested in current handling and how the fault handling works.
Any intel gratefully received!
MoonUnit
Re: Prius boost module PM400DV1A120
Post by MoonUnit »
Best I can come up with is this: https://www.mitsubishielectric.com/semi ... 1a060.html which links to a datasheet.
That product is PM400DV1A060, and it supposedly is rated for 400A and 600V.
The part numbering implies that the module in the post title should also be rated at 400A but for 1200V.
There is some general info on the product range here:
https://www.mitsubishielectric.com/semi ... -l1-s1-v1/.
