Inverter for lion battery
Posted: Tue Nov 28, 2023 8:06 am
by xvyDFatih
Do you have an inverter recommendation that converts the 250-400V voltage range to 220/230V 50Hz voltage range?
It will be used with Li-on battery pack
Re: Inverter for lion battery
Posted: Tue Nov 28, 2023 11:00 am
Moved to renewables.
You gotta be more verbose here. What power level for example? Which comms interface?
Posted: Thu Nov 30, 2023 7:04 am
by xvyDFatih
johu wrote: Tue Nov 28, 2023 11:00 am Moved to renewables.
ok.
Actually there is 48V input to 230Vac inverter for li-on battery. Im looking 250-400V input range.
Also generally inverters for solar panels. They are converting DC to AC. Im looking for li-on battery.
communication is not imported and not neccessary now. Just Im looking an inverter that converts the 250-400V voltage range to 220/230V 50Hz voltage range.
thanks for feednback.
Posted: Thu Nov 30, 2023 12:00 pm
by jrbe
xvyDFatih wrote: Thu Nov 30, 2023 7:04 am ok.
...Im looking 250-400V input range.
..communication is not imported and not neccessary now.
..Just Im looking an inverter that converts the 250-400V voltage range to 220/230V 50Hz voltage range.
Will likely need some amperage / kw goals.
A rotary phase converter setup but with a repurposed ev motor on the input side could work well to get clean power out the other side. Likely much cheaper options but also likely not as simple.
