brkmax/offthrotregen negative or positive?
Posted: Wed Oct 25, 2023 10:14 am
by mane2
In Wiki, it says brkmax / offthrotregen value is positive 0-100%, but almost all parameters I've seen (including the one I use) it's negative. Also reading the code, I think it needs to be negative. (max -100%)
Is there a reason why it's positive number in Parameters page (https://openinverter.org/wiki/Parameters) or, is my and many others parameter values just plain incorrect? :)
Re: brkmax/offthrotregen negative or positive?
Posted: Wed Oct 25, 2023 10:36 am
by mane2
To add confusion, in source code test/test_throttle.cpp has:
Throttle::brkmax = 50;
But then again, I think test source code is outdated.
I'm quite sure the value needs to be negative, but would like to get confirmation on this. Then Wiki parameters page could be updated.
Posted: Wed Oct 25, 2023 11:31 am
Oops, yes please update!
Thanks for checking.
Posted: Wed Oct 25, 2023 11:54 am
by mane2
Thanks for confirming. Updated! https://openinverter.org/wiki/Parameters
