brkmax/offthrotregen negative or positive?
mane2
Has thanked: 40 times
Been thanked: 41 times
Post by mane2 »
In Wiki, it says brkmax / offthrotregen value is positive 0-100%, but almost all parameters I've seen (including the one I use) it's negative. Also reading the code, I think it needs to be negative. (max -100%)
Is there a reason why it's positive number in Parameters page (https://openinverter.org/wiki/Parameters) or, is my and many others parameter values just plain incorrect? :)
mane2
Re: brkmax/offthrotregen negative or positive?
Post by mane2 »
To add confusion, in source code test/test_throttle.cpp has:
Throttle::brkmax = 50;
But then again, I think test source code is outdated.
I'm quite sure the value needs to be negative, but would like to get confirmation on this. Then Wiki parameters page could be updated.
Has thanked: 385 times
Been thanked: 1595 times
Oops, yes please update!
Thanks for checking.
mane2
Post by mane2 »
Thanks for confirming. Updated! https://openinverter.org/wiki/Parameters
