I have a few populated and programmed Bob Carter V3 Lebowski brain boards for sale
Can post anywhere with signed for postage £85 + pnp
You need 3x current sensors 1 per phase for it to work, phase voltage and hall are both optional, there is a big thread on endless sphere if you want to familiarise yourself with it, they are 60mm x 35mm so can be fitted into even the smallest inverters.
The power supply on board uses LM5017 so theoretically its able to be used up to 100v pack voltage direct, or you can run it from an external 5v supply.
BoBC LEBOWSKI Brain boards
- Has thanked: 15 times
- Been thanked: 22 times
