Does anyone know what these are?
The one with the heatsink also has a small relay in the circuit, is it a precharge circuit? The ECU has Vega3 ECU printed on it but I haven't found anything that matches it.
Help IDing some ECUs or VCUs
- Has thanked: 260 times
- Been thanked: 70 times
- Has thanked: 17 times
- Been thanked: 109 times
Re: Help IDing some ECUs or VCUs
Vega3 ECU archived spec. https://ia601808.us.archive.org/16/item ... 1_djvu.txt
Thanks, reading the manual doesn't seem to be useful for high voltage applications.royhen99 wrote: ↑Sat Apr 29, 2023 11:28 am Vega3 ECU archived spec. https://ia601808.us.archive.org/16/item ... 1_djvu.txt
