Page 1 of 3
Honda ima and his abilities An old beetle
Posted: Mon Apr 17, 2023 8:44 pm
by Romale
Hello, people!
I remember there were attempts to work with small IMA inverters more than once, and someone considered them untenable.
I will show in this topic what this wonderful little controller + v3 board is really capable of!
So, the first: a motorcycle made of beetle, 72 volts.
Second: a car weighing 1.4 tons, 140 volts.
Re: Honda ima and his abilities An old beetle
Posted: Mon Apr 17, 2023 8:45 pm
by Romale
Later, I will add something else that will travel on this controller. If you are interested in the settings, feel free to ask.
Posted: Mon Apr 24, 2023 11:20 am
by marcexec
Cool, what amp limits are you running?
Posted: Tue Apr 25, 2023 11:06 am
by Romale
marcexec wrote: Mon Apr 24, 2023 11:20 am Cool, what amp limits are you running?
il1gain 4,09
il2gain 4,09
overcurrent 500
idcmax 300
Posted: Tue Apr 25, 2023 11:16 am
by Romale
there is only one wiring for connecting current sensors (they receive power from the native board of the inverter), and only two wires for each power module to control the PWM relative to the total GND, + two wiring for 12 volts of the native board. this is enough for high-quality operation of the inverter.
I also make an external Wi-Fi module using a sealed type-c connector for this, and I completely fill the inverters with a special compound, which makes them protected from immersion in puddles))
Posted: Sat May 20, 2023 1:59 am
by Ryclanmoto
Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
Posted: Sat May 20, 2023 9:33 am
by Romale
Ryclanmoto wrote: Sat May 20, 2023 1:59 am Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
with this connection, pinswap=4 (pwmout13)
il gain = 4.1
Posted: Sat May 20, 2023 11:33 am
by Ryclanmoto
thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
Posted: Sat May 20, 2023 12:36 pm
by Romale
Ryclanmoto wrote: Sat May 20, 2023 11:33 am thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
so the honda fit has another inverter. it does not contain logic and it needs to immediately send control signals to its native nest. he also has external current sensors, not very convenient.
Posted: Sat May 20, 2023 12:38 pm
by Romale
I have an inverter from fit. I haven't dealt with it yet. later I will make it workable and add information here
Posted: Sat May 20, 2023 12:39 pm
by Romale
in the same topic, an inverter from honda civic
Posted: Sun May 21, 2023 12:25 am
by Ryclanmoto
Romale wrote: Sat May 20, 2023 12:38 pm I have an inverter from fit. I haven't dealt with it yet. later I will make it workable and add information here
cool, we are waiting for the article, I think a lot of people would be interested in the fit inverter and insight
Posted: Mon Jun 05, 2023 3:42 pm
by Romale
update!
I tested an ima inverter from 250 volts and it didn't burn out, up to 250 amps of battery current!
this is a great power for such a small inverter!!
Posted: Mon Jul 03, 2023 5:29 pm
by Leo M
700км пробег работает как часы. Пока без температуры инвертора и вольтметра , но это скоро решим , пока лень морочатся))
Posted: Mon Jul 03, 2023 5:40 pm
by Leo M
Ссылка на телегу на ютубе под видео..
Posted: Tue Jul 04, 2023 4:26 am
by Leo M
Этот инвертор неудобен в переделке. Не вижу смысла с ним заморачиваться.
Posted: Sat Jul 08, 2023 9:37 am
by Ryclanmoto
Leo M wrote: Tue Jul 04, 2023 4:26 am Этот инвертор неудобен в переделке. Не вижу смысла с ним заморачиваться.
Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
Posted: Sun Jul 09, 2023 4:26 am
by Leo M
Ryclanmoto wrote: Sat Jul 08, 2023 9:37 am Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
)))) хотелось бы на это посмотреть… Коль это так легко )))
Posted: Mon Jul 10, 2023 12:42 pm
by Ryclanmoto
Everything has its time, at least managed to move in the project with the help of arduine, twist
Posted: Fri Jul 14, 2023 10:56 am
Leo M wrote: Sun Jul 09, 2023 4:26 am )))) хотелось бы на это посмотреть… Коль это так легко )))
Can you pipe everything through a translator to English please.
Posted: Sat Oct 14, 2023 8:26 pm
by Romale
250 volts (60s li-ion battery). 40+ kW of power! the car is 1500 kg! 130 km / h.
as a motor, a generator with a Nissan Serena. as a ima inverter.
Posted: Sun Oct 15, 2023 4:16 pm
Very nice :)
Why does it have 2 fuel gauges? Why did you need to pull over on the highway? Are you running in field weakening?
Posted: Sun Oct 15, 2023 4:42 pm
by Romale
no, I did not use field attenuation.
two devices are one fuel level, and the second is an economizer (the device is connected to the vacuum on the intake manifold of the internal combustion engine and shows how economically you drive)
Posted: Sun Oct 15, 2023 4:43 pm
by Romale
johu wrote: Sun Oct 15, 2023 4:16 pm Very nice :)
I stopped to shift the gear to a lower gear and test the maximum speed in this gear.
Posted: Sun Oct 15, 2023 5:39 pm
Thank you :)
I thought something went wrong because of the noises.
