Page 1 of 1
Dual BMW Hybrid packs?
Posted: Tue Mar 14, 2023 12:55 am
by Tomas
Would it be possible to use 2 BMW 12kWh batterypacks in parallell?
Re: Dual BMW Hybrid packs?
Posted: Tue Mar 14, 2023 7:14 am
by arber333
Tomas wrote: ↑Tue Mar 14, 2023 12:55 am
Why not? Or perhaps, why not use three for high power and better range?
You will have to decide on how to connect on individual cell/module/pack level. I recommend you draw some diagrams so you can visualize where to put the fuses or pack disconnects...
Posted: Tue Mar 14, 2023 1:28 pm
by lsh3rd
This topic came up on another thread after I asked a question about running more than 6 modules in series for higher voltage. Some users are doing exactly what you are proposing, but the issue is tied to the BMW BMS configuration - you'll probably want to use SimpBMS on these to leverage BMW's factory BMS boards (search this out). The BMS is designed to work with 6 distinct CAN addresses - I believe that the packs can be jumpered to listen on a specific address, but you are limited to 6 choices (Take a look at YouTube user "Good Enuff Garage" - he did several videos on this IIRC). Essentially you will probably need to use a CAN bridge with offset addresses. This should give you an idea of what to search on - I think more extensive answers probably lie in other threads. Hopefully this is enough to get you to the next level.
Posted: Tue Jun 20, 2023 2:14 pm
by FFMan
or use separate can channels on a Teensy i guess would work.
Posted: Fri Jun 23, 2023 5:49 pm
by Ev8
I currently am running 18 modules 6s3p paralleled at the cell level via cell taps and module level, each parallel set of 3 modules share 1 bms, currently working on designing some simple plugin pcbs with fuseable links, but I’ve run without them for 2 years, probably time to do something about that right….
When I built this I was completely reliant on existing code, I would probably follow a different route now…
