Tom, I appreciate all the work you do and don't mean to add to your workload.
When you say you created an index, is this web backend or a visual?
I believe it would help to have a wik creation / editing guide to help others follow the flow of the Wiki. It's great that it's crowd sourced but also chaotic because it's crowd sourced. The current work you're doing might be enough of a template to follow to help avoid the chaos.
Project demystification - make openinverter.org more accessible
- Has thanked: 383 times
- Been thanked: 1584 times
Re: Project demystification - make openinverter.org more accessible
This already looks good and sounds promising. I've done some of that along the way but not systematically
- Has thanked: 211 times
- Been thanked: 593 times
So done the following:
Also created a Parts category where all sub functions can be housed. This way you can "browse" for info from the OEM or the part function.
My intention would be if you have a page with info on a part and how to use it you ONLY have it linked to the OEM/Manufacturer's category NOT the "OEM" category. Then link it to the function group.
This allows a more dynamic linking of cross function group items, like waterpumps under HVAC and Thermal Management for example.
Clean the category usage with the OEM category for example. This should only be used as a "filter" category to get to the OEM you are after or some general comments on the topic.Also created a Parts category where all sub functions can be housed. This way you can "browse" for info from the OEM or the part function.
- Bratitude
- Has thanked: 180 times
- Been thanked: 374 times
Spent the past few days revamping the zombiverter page. Lots of junk, out of date and repetitive sections.
https://openinverter.org/wiki/ZombieVerter_VCU
Broke off some into dedicated pages which will need clean up and work.
Such as the:
leaf-zombie page
Gs450h-zombie page
Openinverter-zombie page
Hardware build
software
programming
Etc
Still a lot of work todo, right now working on the cleaning up fundamental prams and settings
And just a general how-to
Adding in links is needed.
We don’t want to load the main page with too much detailed junk.
Embed videos, pictures, etc greatly appreciated
Such as the:
leaf-zombie page
Gs450h-zombie page
Hardware build
software
programming
Etc
- Bratitude
started a LEAF PDM page, if you have info, please dump https://openinverter.org/wiki/Nissan_leaf_pdm
