[WIP] Audi A2 refreshing an old conversion
Posted: Sun Nov 20, 2022 4:43 pm
Hi all,
I am refreshing an Audi A2 wich has been converted to electric in 2012.
It currently has the following components
The batteries now seem to be dead reading really low voltages.
I had seen some success from other forum users with the opel corsa e / peugeot 208 battery pack (thank you all for documenting).
I have decided on using those battery modules.
Using four of them in series would give me a 24s battery pack. This would work nicely with the existing charger motor controller etc. I am planning to eventually install several 24s packs each with there own bms and contactors.
- Akoe 132 motor nominal 28kw max 40 kw. mated to the original gearbox.
- DMC PAC950TL01 AC Traction Controller.
- 30s lifepo4 180ah battery pack 108V
- emus bms
- zivan charger
- victron dc/dc converter
