Using the inverter to generate household AC voltage
Posted: Sun Oct 16, 2022 6:35 pm
Looking at inverters built I quickly realized that most of them look sketchy in an environment exposed to constant vibration as well as the pricing skyrockets above a few kW of output power.
I thought of the idea of having say a prius inverter used in 50Hz 230ish Vac 3phase output mode with DC ground being the N connection connected to a 200ish Volt battery.
I could not find any prior art regarding this usage case. What do you think about this?
