Leaf gen2 OVERCURRENT
Riwi
Been thanked: 10 times
Post by Riwi »
Hi!
Im getting overcurrent errors when using my battery as power. approx 125V.
I ran the controller on 40V DC and was able to spinn the motor without faults.
I changed the oculim to 100A and connected the motor to 125V, did precharge and connected pin 22 to get into opmode RUN.
Used a normal throttle, hal, and connceted pin 16 to engage FWD.
Motor spins up, maybe 2-3 seconds, low rpm, and the hits OVERCURRENT and opens the contactor.
I the log I see that Iq and il1 are very high:
Any ideas?
Riwi
Re: Leaf gen2 OVERCURRENT
Post by Riwi »
Settings:
Riwi
Post by Riwi »
I noticed that syncofs is 0. Is that correct?
Has thanked: 368 times
Been thanked: 1536 times
syncofs 0 is a good starting value for the Leaf motor. ocurlim of 100A is a bit slim though, go to 400A for testing and 900A for actual use.
Riwi
Post by Riwi »
johu wrote: Fri Feb 04, 2022 1:36 pm syncofs 0 is a good starting value for the Leaf motor. ocurlim of 100A is a bit slim though, go to 400A for testing and 900A for actual use.
Ok, the first test was done using default settings, think it was 700A, and that hit the roof as well.
can you write "get pinswap" into custom command and then post here the output (above the parameter list)
Riwi
Post by Riwi »
johu wrote: Sat Feb 05, 2022 3:48 pm can you write "get pinswap" into custom command and then post here the output (above the parameter list)
hmm, thats correct. If you go in Manual Mode and command 1A of d current, what happens?
