Tough BMS
Posted: Thu Aug 01, 2019 11:31 am
I have used another distributed BMS for a long time now. Surprisingly i had absolutely NO issues with it.
It was designed to dissipate energy from cell at 4V per cell. Not 4.2V but 4V since this way i am assured of longer cell life and from 4V to 4.2V it is like 30minutes of charging. During that time even the dummest charger starts to go to CV.
I used TL431 reference diodes to trigger PNP/NPN pair. NPN transistor is actually NFET capable of 5A continuous drain. However i noticed even 1A in closed space can be a fire hazard. So i use 0.5A drain. It works in my car for 4 years now. No events
Also i designed a LV alert into each module. I used Microchip TC54 voltage trigger to signal EMPTY at 3V per cell. While there is some power still in the cell at 3V it can drop to 2.5V in under a minute! I use optocooupler PC817 to signal events for a single cell. Currently i have this alarm set so it lights red LED on my dash. But i could just as easily connect BMS pin of Rev 2 inverter to put the car in "turtle mode".
There is also provision to use HV alert when a single cell reaches 4V BMS loop can slow the charger to 1A so that all cells align.
I tried to eliminate PNP transistor, but i found out its base hysteresis keeps TL431 from turning on too fast. This was designed explicidely to work with LiPo cells. It is a rather crude system with low parts count, but it is also EMI proof and reliable. I made 8S boards because i use cells in packs of 8.
You are free to use this system and further develop it if you like.
