Porsche canbus dbc files
Posted: Mon Aug 09, 2021 10:49 am
by EV_Builder
Ok basically in need of any dbc file you have or can find from any Porsche.
Trying to shed some light on the mysteries on my Panamera 970...
Re: Porsche canbus dbc files
Posted: Tue Aug 10, 2021 12:26 pm
by EV_Builder
nobody anything?
i thought that i saw some porsches converted on here? How do you guys have the ABS unit happy?
Posted: Wed Aug 11, 2021 5:25 am
by Isaac96
EV_Builder wrote: Tue Aug 10, 2021 12:26 pm nobody anything?
There's one in the Zero EV build thread.
viewtopic.php?p=3714#p3714
My Porsche (2000 986) has minimal CAN and the ABS works fine as it is. I want to switch the cluster out for a CAN one though.
Posted: Fri Aug 13, 2021 1:55 pm
by EV_Builder
thank u very much for your response!
Posted: Fri Aug 13, 2021 4:30 pm
Best thing to do would be look if someone engineswapped one and reach out to them.
Thanks how I found the boxster canbus info. However the boxsters are very very crude and the ABS system is mainly standalone.
Posted: Sun Sep 05, 2021 9:19 pm
by EV_Builder
tom91 wrote: Fri Aug 13, 2021 4:30 pm Best thing to do would be look if someone engineswapped one and reach out to them.
Do you have it? Can you share?
Posted: Mon Sep 06, 2021 8:43 pm
by EV_Builder
Ok guys! I'm like in maniac mode = on now!
Look at this:
I build-ed further on my CANBus suite so now it accepts 3 Adapters (USB peaks) and i can play with stuff.
The ID list you see is coming from that particular interface.
underwater i re-join (or not) the canbusses again by software (forwarding messages).
@Damian; I also made a very nice CANBus Log comparer...maybe i pull that part out one day and release it to the open...
! = Unique value in this side
RED = Different then other side
Posted: Mon Sep 06, 2021 11:36 pm
by EV_Builder
In action injecting my own data:
Posted: Tue Sep 07, 2021 8:44 pm
by jon volk
Does the .dbc contain data for individual wheel speed off the ABS system? I believe it uses the same style as the E46M3, which is common as a standalone motorsport integration. Im interested in possibly using the Boxster version as the dynamics are likely programmed closer to my needs in terms of vehicle weight distribution. Id like to pull wheel speed data and integrate that into traction control.
I have the E46M3 data, but havent delved into the Porsche stuff.
Posted: Wed Sep 08, 2021 9:34 am
by EV_Builder
If you mean the Porsche DBC from internet: yes.
BO_ 680 WheelSpeeds: 8 Vector__XXX
SG_ WheelSpeedRR : 48|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedLR : 32|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedRF : 16|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedLF : 0|16@1+ (1,0) [0|65535] "" Vector__XXX
In my car I have never driven it yet so no moving captures yet.
Posted: Wed May 24, 2023 12:25 pm
by RoDerrick
Hi ,
I got some battery modules from a cayenne (Bosch 13s 48 volt) , they have canbus.
Do you think it is possible to get data from it through CAN ?
https://transistor-man.com/PhotoSet/doo ... iagram.jpg
Would be great for home storage.....
Thanks Rod
