GS450h compatible transmissions and inverters
Posted: Thu Jul 22, 2021 3:02 pm
by gfournier
Hello,
I am about to buy a GS450h transmission and inverter. I am trying to find the latest information on the compatibility with the boards that Damien created (including latest ZombieVerter/V3 VCU).
So far I got this but i'd like some sort of confirmation before I buy.
Compatible inverters
- G9200-30040
- G9200-30061
- G9200-30051
- G9200-30040
- G9200-30030
- G9200-30180
- G9200-30170
- G9200-33171 (Camry)
Transmissions:
- 30910-30021
Thanks!
Re: GS450h compatible transmissions and inverters
Posted: Mon Jul 26, 2021 9:03 am
by Lwerewolf
Anything that's put in a 3rd gen gs450h or a crown hybrid (GWS204 which is basically the 3rd gen 450h) should share the same control protocols. Transmissions-wise, as far as I know there are no differences.
Posted: Mon Apr 18, 2022 9:21 am
by dukbilt
gfournier wrote: ↑Thu Jul 22, 2021 3:02 pm
Hello,
- G9200-30040
- G9200-30061
- G9200-30051
- G9200-30040
- G9200-30030
- G9200-30180
- G9200-30170
Transmissions:
- 30910-30021
Thanks!
So - is it confirmed that the G9200-33171 (Camry) inverter DOES work with the Openinverter brain board?
Thanks,
dukbilt
Posted: Mon Apr 18, 2022 3:29 pm
by gfournier
dukbilt wrote: ↑Mon Apr 18, 2022 9:21 am
I was basing the inclusion of this inverter because of this post ->
viewtopic.php?p=28941&hilit=33171#p28941. It seems to work with damien's VCU.
Posted: Fri Apr 22, 2022 5:18 am
by dukbilt
So - I'm looking at a G9200-33171 Inverter/Converter, and a P314 transaxle.
Has anyone got experience with this combination, running?
Regards,
dukbilt
Posted: Fri Apr 22, 2022 11:24 am
by SuperV8
Strange I can't see any part with G9200-33171 when I search in my Toyota Catalogue.
Which Camry platform/model year?
If I search Camry
Model Name: CAMRY/HYBRID (ASIA) (05.2006 - 07.2012)
Model(Frame No): AHV40R-JEXGBT
G9200-33100 Replaced by: G9200-33101 INVERTER ASSY, W/CONVERTER 07.2009 - 03.2012 AHV40
Posted: Fri Apr 22, 2022 11:55 am
by dukbilt
AVV50 - Australian variant, 2012-2017 I think.
Posted: Fri Apr 22, 2022 12:52 pm
by SuperV8
dukbilt wrote: ↑Fri Apr 22, 2022 11:55 am
For the AVV50 this is what I can see for the inverter:
This might be usefull catalogue:
https://japancars.ru/index.php?route=catalog/toyota
Model Name: CAMRY/AURION/HV(ARL) (10.2011 - 10.2017)
Model(Frame No): AVV50R-DEXDBQ
G92A0-33020 Replaced by: G92A0-33021 INVERTER ASSY, W/CONVERTER 01.2012 - 10.2013 AVV50
G92A0-33021 INVERTER ASSY, W/CONVERTER 11.2013 - 04.2015 AVV50
G92A0-33021 INVERTER ASSY, W/CONVERTER 04.2015 - AVV50
Posted: Sat Apr 23, 2022 12:20 am
by dukbilt
Here are photos of 2 candidate inverters (both from Toyota Camry Hybrids - AVV50, with P314 Trans). According to the only identifier I can make out, the part numbers are
both G9200-33171.
Using the VIN for an Australian Camry - 6T1BD3FK30X142521 - the website
https://japancars.ru/index.php?route=ca ... lk_id=8431 shows:
- Reference number - G9200
- vendor code - G92A0-33021
- Description - INVERTER ASSY, W/CONVERTER
- Release period - 11.2013 - 04.2015
- Note - AVV50
The thot plickens!
dukbilt
Posted: Tue Dec 12, 2023 3:43 pm
by Tachopis
Thanks,
dukbilt
Hi dukbilt, did you manage to confirm this? I'm about to buy the inverter for the GS450h and there are big differences in prices. Thanks
Posted: Sun Apr 14, 2024 2:29 am
by dukbilt
No, I wasn't able to confirm that at all.
Please let me know how you go, if you pursue that.
I'd start by looking at what the Logic Board and Power Board part numbers are, and if it has a 'Compatible 50 pin connector'. If they match anything on the wiki (
https://openinverter.org/wiki/Toyota_Prius_Gen3_Board) then that inverter might be compatible.
HOWEVER - it seems the G9200-33171 DOES work according to
viewtopic.php?p=27600#p27600
dukbilt
