CCS Plug
Posted: Sun Jun 20, 2021 7:08 pm
by EV_Builder
Does somebody have acces to the actual plug?
Can you share some pictures and dimensions?
What i need is a small sketch of the debt/height of the part that tries to enter the old Filler spot but on sport cars its not allot of room there...
p.s. I bought the socket from an ID3 including the wiring etc
Re: CCS Plug
Posted: Sun Jun 20, 2021 7:17 pm
by mikeselectricstuff
This is a Duosida plug - it's possible that others (e.g. liquid cooled) might be bigger
Re: CCS Plug
Posted: Sun Jun 20, 2021 7:20 pm
by EV_Builder
I found this one!
So i guess the standard is 100x70mm...
it' s the DUOSIDA :D :P
Damien can you confirm these dimensions? i saw one in one of your movies... :lol: ;)
Re: CCS Plug
Posted: Wed Jun 29, 2022 1:23 am
by brainstorm
If one were to 3D print that plug (like other folks have done w/ Chademo:
where would one be able to source the internal metallic lugs and how are they welded (pressed) to which AWG cables?
Re: CCS Plug
Posted: Wed Jun 29, 2022 8:15 am
Re: CCS Plug
Posted: Wed Jun 29, 2022 12:07 pm
by brainstorm
Yeah, I've seen some models already, i.e: https://grabcad.com/library/tag/ccs
What I'm interested is about the female metal lugs on the CCS2 gun: are they commercially available at all (i.e as spares?). I believe those lugs are called "contact tubes" according to IEC 62196.
I'd really like to avoid grinding copper rods and doing nyckel electrolysis to avoid corrosion and whatnot, seems quite labor intensive:
Re: CCS Plug
Posted: Sat Jul 02, 2022 3:53 am
by CCSknowitall
Some commercial cables do have replaceable contacts. They're not exactly hobbyist level prices, however.
Duosida plugs are relatively inexpensive on Aliexpress. I would suggest getting something with a cable though.
