kit v2 vs v3 ... what is new ?  [SOLVED]
chentron
Has thanked: 42 times
Been thanked: 10 times
Post by chentron »
hi to all
4 years ago i decided to make a conversion to a small 4x4 suzuki samurai. I was following in DIIY forum.
I bought a v2 kit to johannes, but when a new children was born so I stopped the project.
lot of changes in 4 years, but now I want to restart project.
Have AZD motor AC24LS , contactor, capacitors, IGBT and v2 kit mounted, flashed and tested. Car to be converted is now a suzuki vitara long body
I dont find the differences with the info in the web/wiki , so what i am missing with the new v3 kit ?
Has thanked: 368 times
Been thanked: 1542 times
Re: kit v2 vs v3 ... what is new ?  [SOLVED]
The V3 mainboard is mainly just an SMD version of V2. Only hardware addition is the resolver exciter, needed for synchronous motors only and a socket for the wifi module. So if you run an asynchronous motor you won't lack any feature as they all run the same software.
