Hi Love the Project great work,
How goes your progress ?
i would be slightly concerned with the high voltage wiring. have two split packs in parallel such a distance apart could possibly cause uneven loading on high load made worse when the battery try to balance afterwards. having wiring live outside times when the car isnt being used could also be dangerous if the wiring was to be damaged.
looking forward to seeing some more pics
RWD Tesla Powered CRX
- Been thanked: 6 times
Re: RWD Tesla Powered CRX
Just found your build via the YT link you shared above. Looks like a great build. And now you've got me wondering if I could go RWD on my gen 1 Honda Insight!
- Has thanked: 46 times
- Been thanked: 15 times
Happy EV build!
Have you figured out the M3 compressor? I believe it's CAN messanging controlled.
HI Martin,
just viewed the WCSC YT interview of your CRX. Absolutley great source of information! I am in the process of conversion as well. However, I decided to grab Ford's Eluminator for my '90 Ford Bronco II 2WD. Moving forward, I noticed it has been a while since your last post here, where does the project sit?
Dave
Dave
