DIY rev2 inverter throttle error
Posted: Fri Feb 05, 2021 1:01 pm
Hi Folks
Today i tried to drive Mazda a bit. I managed to get it from the parking space in reverse and then prepared to drivoff. Inverter threw an error. I reset the error and tried again. I wasnt able to start even when i put my transmission in neutral. Something i was able to do when i first started the car.
Then i tried to see the faults if any. I connected to Wifi interface and i saw only a warning "Warning Throttle".
There was no overcurrent event only throttle issue.
When i started inverter again and observed the graph i got normal throttle response. This means throttle signal is getting to inverter. There was one thing though. When i pressed the brake its vacuum pump went on and throttle signal went down a few points. Probably a reference issue in 12V power supply.
Then i tried to start in manual to get the motor to spin. I used 1Hz and 50% amps setting at 350Vdc. No luck getting inverter to start again...
I didnt see any additional errors that accompany faults in IGBTs...
I need to take mainboard apart....
Anyone has any ideas?
