Hi Folks
Today i tried to drive Mazda a bit. I managed to get it from the parking space in reverse and then prepared to drivoff. Inverter threw an error. I reset the error and tried again. I wasnt able to start even when i put my transmission in neutral. Something i was able to do when i first started the car.
Then i tried to see the faults if any. I connected to Wifi interface and i saw only a warning "Warning Throttle".
There was no overcurrent event only throttle issue.
When i started inverter again and observed the graph i got normal throttle response. This means throttle signal is getting to inverter. There was one thing though. When i pressed the brake its vacuum pump went on and throttle signal went down a few points. Probably a reference issue in 12V power supply.
Then i tried to start in manual to get the motor to spin. I used 1Hz and 50% amps setting at 350Vdc. No luck getting inverter to start again...
I didnt see any additional errors that accompany faults in IGBTs...
I need to take mainboard apart....
Anyone has any ideas?
DIY rev2 inverter throttle error
- Been thanked: 1914 times
Re: DIY rev2 inverter throttle error
Throttle warning means throttle went more than 200 digits outside your configured window. Maybe some ground fault? Something came loose or corroded.
- Has thanked: 166 times
- Been thanked: 411 times
Strangely my scope measures hall sensor voltage change really fine. It must be something on the board then....
But why i cant run the motor in manual mode?
Ok i traced non movable motor to 12V - 15V driver DCDC PSU. It burned out and drivers were unpowered. I replaced that and motor spins good.
That didnt take away strange error involving throttle and throwing out contactor every time throttle moves to origin position. Or if i press the brake for that matter.
If i manage.to rev the motor and drive i can add throttle as i whish. However if i come close to a stop inverter would throw error.
That looks very much like an encoder issue. But there is no error associated with it!
I use AB encoder and i remember you said brain doesnt show encoder errors for that type.
Shall i open the motor and see encoder state?
Yes correct, no diagnosis on AB encoders.
