More progress on the exterior of the battery box.
1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
- mdrobnak
- Been thanked: 5 times
Re: 1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
Awesome work. I can't wait to see how this turns out.
I did some math and I think the Energy modules will be fine for my long-term use. But I think you're gonna have lots of fun with your setup!
-Matt
-Matt
Long while since my last post but progress has been steady.
Obligatory first test drive!
Make note that somewhere between bench testing and wiring the car... R/D got switched and I nearly took out my tool chests.
- Has thanked: 46 times
- Been thanked: 15 times
Re: 1993 FD Rx7
Does it work on the SDU as well?Boxster EV wrote: ↑Tue Dec 22, 2020 9:00 am Yes, buy the 23 pin connector from DIY autotune. It makes the wiring a breeze and takes out the element of doubt regarding bad connections at the plug (this plug take A LOT of abuse from the weather and road debris). You will however have to de-pin the encoder wires from the 23 pin and replace them with shielded cable.
https://www.diyautotune.com/product/ms3 ... r-harness/
