Page 38 of 50
Posted: Sat Nov 05, 2022 11:08 am
by ginetto
m.art.y wrote: ↑Sat Nov 05, 2022 10:57 am
Hi guys, just wanted to ask if anybody used a Duosida CCS socket with a LIM and got it working? I read through the thread and a lock seems to be a must. By lock is it meant the Type2 socket lock on the top as in the photo? If so it is rather high profile has anybody seen any smaller versions of the lock?
AFAIU can be mounted also laterally. BTW I do not have direct experience.
Posted: Sat Nov 05, 2022 12:28 pm
by tom91
Very easy to get working, all is on the wiki
https://openinverter.org/wiki/BMW_I3_Fa ... LIM_Module
there are lower profile locks, like
https://zero-ev.co.uk/shop/lockpincp-lo ... desc#attr=
Posted: Sun Nov 06, 2022 1:38 pm
by EV_Builder
Or go to a breaker of an ID3 / ID4 that's what i did.
It has the lock lateral...
Posted: Sun Nov 06, 2022 3:50 pm
by asavage
Posted: Mon Nov 07, 2022 4:29 pm
by Eltis
Hello everyone, help to solve the problem. I have a lim 2014 USA.(...646) The welding test passes normally. I see. 272,false,Rx,0,8,33,F3,01,11,FF,FF,FF,FF, Then I connect the connector of the charging station, the LED starts to glow yellow. 3B4,false,Rx,0,8,00,FF,31,F0,BC,FF,00,00. Everything seems to be going well. But only I start seeing this message: 3E9,false,Rx,0,8,08,52,11,00,00,00,00,00Everything stops and the LED starts flashing red. At first I thought I had a port blocking problem. I even wired a separate switch to manually enable the lock. Still nothing happens.
Posted: Mon Nov 07, 2022 5:31 pm
by tom91
Eltis wrote: ↑Mon Nov 07, 2022 4:29 pm
Hello everyone, help to solve the problem. Still nothing happens.
tom91 wrote: ↑Fri Nov 04, 2022 12:16 pm
Provide a capture if you need help.
Posted: Tue Nov 08, 2022 3:29 am
by Eltis
Ok. Thank you.
Posted: Tue Nov 08, 2022 12:19 pm
by muehlpower
Eltis wrote: ↑Tue Nov 08, 2022 3:29 amOk. Thank you.
Did you notice that the proxy has to be connected to pins 2 and 6 on USA models? BTW, US and EU LIMs are the same and can be recoded.
Posted: Tue Nov 08, 2022 1:03 pm
by tom91
A question to every one who has a working vehicle with the LIM working, I have yet to get my first project running myself.
What outputs does the LIM generate upon Plug Insertion to allow the rest of the vehicle to wake up? I have yet to figure out if the LIM signals can be used to wake up the various required other items in a vehicle to allow starting charge from a "Ignition Off" situation.
Posted: Tue Nov 08, 2022 1:57 pm
by Eltis
muehlpower wrote: ↑Tue Nov 08, 2022 12:19 pm
I paid attention to it. I bought the lim together with wires and a conectors. Do I need to put an additional jumper between 2 and 6? Because now there is no connection.
Posted: Tue Nov 08, 2022 4:21 pm
by muehlpower
As I said, on EU models, pin 6 remains open and proxi is connected to pin 2, on US models proxi is connected to both, pin 2 "and" 6.
Posted: Wed Nov 09, 2022 4:49 am
by asavage
Eltis wrote: ↑Tue Nov 08, 2022 1:57 pm
https://openinverter.org/wiki/BMW_I3_Fast_Charging_LIM_Module#Connectors_and_Pinouts
If your LIM was sourced from a US-coded vechicle, very probably you will need to jumper 2B-2 to 2B-6.
Posted: Sun Nov 13, 2022 12:13 pm
by Eltis
Hello. Is there an error in the voltage meter circuit? By connecting the polarity of the power supply TLV 6001 ?
Posted: Sun Nov 13, 2022 12:15 pm
by Eltis
Posted: Sun Nov 13, 2022 12:32 pm
by tom91
Eltis wrote: ↑Sun Nov 13, 2022 12:13 pm
Hello.
Please do this if you need help, you are saying you get to a certain point in the sequence so there will be clues.
Posted: Sun Nov 13, 2022 2:21 pm
by muehlpower
Eltis wrote: ↑Sun Nov 13, 2022 12:15 pmSensing.png
There are different types of TLV6001. With the "R" version, pin 5 = V-, pin 2 = V+. Without "R" it's the other way around. With the "U" version, the inputs and outputs are different.
Posted: Sun Nov 13, 2022 8:37 pm
by Eltis
muehlpower wrote: ↑Sun Nov 13, 2022 2:21 pm
Thank you.
Posted: Sun Nov 13, 2022 8:41 pm
by Eltis
tom91 wrote: ↑Sun Nov 13, 2022 12:32 pm
For now, I took a break, remaking my Arduino controller. At stm 32. When I'm ready, I'll definitely show my capture . I'm learning now cubeIDE .
Posted: Sun Nov 13, 2022 8:51 pm
by Eltis
is it possible to install id instead of rid? By changing the polarity of the power supply?
Posted: Fri Nov 18, 2022 9:51 am
by larsrengersen
Bit of a generic overall question regarding Voltage and Current deviation.
With CHAdeMO it is up to the car (controller) to measure and manage this.
In the LIM .dbc I found DCFC_V_Diff and DCFC_I_Diff
So my question is, is Voltage and Current deviation management also needed for CCS?
And if yes? Should the LIM do that? And if yes, how?
Posted: Fri Nov 25, 2022 11:56 am
by Zapatero
I'm very sorry I'm advance as I'm sure this has been asked. But although i searched and red the wiki page i couldn't find the answer:
If I use an onboard AC charger that wants the CP and PP contacts, too, can i just connect them parallel to the LIM?
One this is clarified I'd like to add this information to the wiki page.
Thanks so much
Posted: Fri Nov 25, 2022 12:13 pm
by larsrengersen
Zapatero wrote: ↑Fri Nov 25, 2022 11:56 am
It's already in there
Under AC charging (on board charger control)
Posted: Fri Nov 25, 2022 12:22 pm
by Zapatero
Im sorry, a classic case of user stupidity... Thanks for the heads up
Posted: Sun Nov 27, 2022 6:21 am
by Zapatero
If I decide to switch CC and CP signal with a relay, what would be the indicator for the relay to know if it's open or closed. Which signal can i use to recognize if a Type2 or CCS plug is plugged in?
Posted: Sun Nov 27, 2022 6:41 am
by larsrengersen
Perhaps there are other ways too, but I'd look at CAN message 0x3B4 from the LIM and within that at the Pilot_Status.
As soon as that becomes 0x01 AC not Ready or 0x02 AC Ready you know the LIM has detected a PWM signal at the CP line that corresponds with AC charging.
