Page 4 of 4
Re: Peugeot e-208 CATL modules BMS interface
Posted: Wed Aug 02, 2023 9:24 am
by m.art.y
EV_Builder wrote: ↑Wed Aug 02, 2023 8:18 am
Are the 50kwh packs 6S2P?
Yes
Posted: Wed Aug 02, 2023 11:45 am
by EV_Builder
Interesting there are also 6S1P out there.
Posted: Fri Oct 06, 2023 11:03 am
by Goldveet
Clanarn wrote: ↑Mon Aug 01, 2022 3:19 pm
I have a couple of MAX17841 interface boards left if someone is interested. 40eu.
Pm me for schematic.
Hello,
I'm jealous of you having such card, i'm looking for it since a long time and just discover this forum, I cannot send you message, maybe because i'm new user, so I will do it here in case you read it
@inaglasshouse
For your project with e-208 module, how is it going? if you need any help to configure voltage/power map dont hesite to MP me. I can help to ensure you keep it all safe
Posted: Tue Oct 24, 2023 9:15 am
by OmulCuBateria
Goldveet wrote: ↑Fri Oct 06, 2023 11:03 am
Hello,
@inaglasshouse
Can't PM you either,
Open and good advice are always welcome if they enable us to use (or re-use) in all safety these modules. Do you have any recommendations, mainly voltage working range, current limits and derating when charging towards maximum voltge?
Thanks again,
Posted: Tue Oct 24, 2023 9:20 am
PM only works once your first post was approved. This is to lock out spammers.
Re: Peugeot e-208 CATL modules BMS interface [SOLVED]
Posted: Fri Nov 24, 2023 6:15 pm
by evdc
VWJoe wrote: ↑Thu Dec 01, 2022 10:07 am
Yep code can be found in this thread
viewtopic.php?p=20335#p20335
I've rewritten this code for my project (using the Peugeot Battery), it needs a bit of tidying before I publish it here, but I hope to do this soon.
Hi VWJoe, I have a battery from an Opel Corsa-e arriving soon and I'm thinking of using it for a solar system. I saw this post and I would be very grateful if you could send me the code you have for this type of battery connection. You can write me PM
Posted: Mon Feb 05, 2024 7:23 am
by usus
Does anyone has the code runnig on ESP32?
Posted: Tue Feb 06, 2024 2:09 pm
by EdvartsW4E
Very nice tread, thank you for the info!
Does somebody have UN38.3 or any other datasheet for the CATL 6s2p module?
Posted: Wed Feb 07, 2024 1:33 pm
by usus
Posted: Wed Feb 07, 2024 3:37 pm
by m.art.y
EdvartsW4E wrote: ↑Tue Feb 06, 2024 2:09 pm
Datasheet for the cells here:
Interestingly the chemistry proportions are not listed but elsewhere I found 811 mentioned. Could somebody confirm?
Posted: Thu Feb 08, 2024 12:54 pm
by EdvartsW4E
m.art.y wrote: ↑Wed Feb 07, 2024 3:37 pm
THank you.
But this is for CALB cells, while the e208 use CATL cells/modules
Posted: Fri Apr 19, 2024 11:40 am
by m.art.y
Hi, question to those who have been using those modules. What happens when a module or two are disconnected from the BMS daisy chain? Can the data still be read and cells balanced? Each module has it's own BMS slave board, right?
Posted: Sat Apr 20, 2024 7:04 am
by manny
Yes the BMS daisy chain will work with any number of modules. but the daisy chain wiring needs to be changed to close the chain.
m.art.y wrote: ↑Fri Apr 19, 2024 11:40 am
Yes
Posted: Mon Apr 22, 2024 7:30 pm
by VWJoe
Depends how you have them linked, the first is by the last module having a loopback hard-wired, in this case, if any module is disconnected all comms stop, the second is to have the slaves setup to a loopback (software), in this case, if you have 16 modules and say number 10 is disconnected the BMS would report 9 modules.
Posted: Tue May 28, 2024 11:53 am
by woleg
If anyone is having no comms issues with these modules there may be a fundamentally different slave IC in their packs.
Tried all the code shared here only to find the modules I have are MAX17854 as confirmed from reading register 0x0.
Currently working my way through new code based on the manufacturers example code using an ESP32. Works fine so far.
https://github.com/analogdevicesinc/MAXREFDES1277
Posted: Mon Sep 09, 2024 5:57 pm
by martii
Yes
Posted: Tue Sep 10, 2024 7:46 am
by EV_Builder
woleg wrote: ↑Tue May 28, 2024 11:53 am
Yeah; the 17854 is found in CATL's 6S1P too.
On my site there is a list of compatible batteries and modules.
