Nissan Leaf
13
38%
Toyota Prius
15
44%
Other (No Outlanders in US)
6
18%
Total votes: 34
Ev8
Has thanked: 44 times
Been thanked: 172 times
Re: [DRIVING] 1984 Voltswagen Rabbit Prius Gen 3 ZOMBIE
Post by Ev8 »
Great work Greg! I don’t generally like taking my bmw modules below 3.4v cell I start getting big deltas under load if I do, so what’s the max battery current you’ve seen pulled? Maybe log idc and udc and go full throttle so we can work out how many kw you’ve managed to extract from the Prius!
Has thanked: 328 times
Been thanked: 847 times
The Prius setup is current stuck at just shy of 20kW running just MG2. Working on sorting out the code like I done for the IS300h.
We should be getting close now, found some more logs to review.
TRWIKI
Has thanked: 20 times
Post by TRWIKI »
I am following the work here with great interest.
And I thank you very much for the extensive documentation
I have/had also planned to use the Prius drive and had also bought the drive.
However, I have read that the drive delivers little speed. Unfortunately, high speeds have not yet been achieved with the Audi A2 project. The characteristic curves of the MG2 also show that the engine is not very revy and does not want to spin high (approx 3000 rpm).
I'll keep my fingers crossed and wish you every success in achieving top speeds much higher than 53mph.
Has thanked: 630 times
Been thanked: 1607 times
TRWIKI wrote: Sun Jul 21, 2024 10:37 am I am following the work here with great interest.
hi, thanks for the kind words, I am sure you have seen WeberAuto videos where Professor Kelley compares both the Gen 2 Prius the one in the Audi A2 project and the 3rd gen which I am using. He mentions that Toyota in electric mode only, ie EV mode, deliberately prevents the 3rd gen from spinning higher than 6,000 RPM though it is rated up to 13,500. Just an FYI the second gen has a chain drive the 3rd gen does not. Now take a look at my log numbers and you tell me if it caps at 3000 RPM, posting raw log data as to prove no tempering, speed is the RPM spot value we are looking for below (the table below is sorted by speed, not by time for demonstration purposes)
Note how the torque in the last column is capped for some reason at 3500, that's what Tom is looking into, once we break that limit, sky (or 13,500 RPM is the limit, ha ha) keep your fingers crossed
Timestamp udc2 idc speed torque
2024-07-15T16:16:20.076 316 -63 6441 3500
2024-07-15T16:16:19.214 316 -63 6407 3500
2024-07-15T16:16:20.683 321 -2 6382 0
2024-07-15T16:16:18.489 316 -64 6347 3500
2024-07-15T16:16:17.847 316 -64 6285 3500
2024-07-15T16:16:17.221 316 -65 6236 3500
2024-07-15T16:16:21.273 321 -2 6215 0
2024-07-15T16:16:16.574 316 -65 6193 3500
2024-07-15T16:16:15.903 316 -66 6138 3500
2024-07-15T16:16:15.266 316 -66 6119 3500
2024-07-15T16:16:14.642 316 -66 6063 3500
video queued up to the 1st vs 2nd vs 3rd gen Prius MG2 rotor speed comparison
Ghia66
Has thanked: 750 times
Been thanked: 65 times
Post by Ghia66 »
This is going to be a rocket!
royhen99
Has thanked: 22 times
Been thanked: 134 times
Post by royhen99 »
Gregski wrote: Sun Jul 21, 2024 1:36 pm Note how the torque in the last column is capped for some reason at 3500, that's what Tom is looking into, once we break that limit, sky (or 13,500 RPM is the limit, ha ha) keep your fingers crossed
It's not the 3500 torque request that is the problem, this is the max value used in the GS450H, GS300H and I assume the Prius. The power is limited by values in the htm serial data. As far as I can tell the location for the discharge power is at bytes [78] and [79] which are currently set for 21kW.
royhen99 wrote: Mon Jul 22, 2024 5:21 pm It's not the 3500 torque request that is the problem, this is the max value used in the GS450H, GS300H and I assume the Prius. The power is limited by values in the htm serial data. As far as I can tell the location for the discharge power is at bytes [78] and [79] which are currently set for 21kW.
Correct, they have been altered in test versions of firmware with no change. So the search continues.
Wait where are you referring to specifically in the code?
royhen99
Post by royhen99 »
I am referring to the code. At the moment the discharge power is at byte 87 and 88 which looking at various logs is more or less fixed values and not the power limit, also a negative number which does not match GS450 / GS300H. Looking at both prius and auris logs the discharge power ( in watts/10) is at bytes 78 and 79 and the regen power is bytes 76 and 77 ( -Watts/10 ).
I could be wrong but these byte seemed the most plausible.
royhen99 wrote: Mon Jul 22, 2024 5:58 pm I am referring to the code. At the moment the discharge power is at byte 87 and 88 which looking at various logs is more or less fixed values and not the power limit, also a negative number which does not match GS450 / GS300H. Looking at both prius and auris logs the discharge power ( in watts/10) is at bytes 78 and 79 and the regen power is bytes 76 and 77 ( -Watts/10 ).
Okay so you are not looking at code but logs. As I have said we have tried exactly this and are currently in the process of trying other variations.
Woodfie
Has thanked: 221 times
Been thanked: 96 times
Post by Woodfie »
From some Prius gen2, and gen3, tampering with added battery packs, The limit of 21 kw which is the limit of what the boost converter can transfer. With the Boost converter bypassed, hopefully your expertise in code massaging, to free up this potentual available power will come to fruition, in near future.. 😉
Proton
Has thanked: 227 times
Been thanked: 57 times
Post by Proton »
@Gregski
So how fast the 2 motor combination with Zombie can go? Would this work better in a Prius if you just remove the ICE engine and and leave everything else in place?
Proton wrote: Thu Dec 05, 2024 7:22 pm @Gregski
these are all excellent questions, at this time we still don't know how fast we can even go on just one MG2 motor as we are up against some built in TOYOTA maximum speed limit of 52 MPH
in order to run both motors we need to weld the power split device inside of this transmission, something I am a bit intimidated to attempt with my 120 volt 20 amp MIG welder
and yanking the ICE out of a Prius to run it as 100% electric is an idea that's been in my head for years now, not sure how we would satisfy all the pesky is the engine present ie is there a tach signal for example requests by the OEM computer to do so, maybe we would run it with the Zombie but that would present the same set of problems
I really wanted EV VW and it was available, so I went in the kitchen came back 2 minutes later and it was taken!!!
0tik
Been thanked: 17 times
Post by 0tik »
But this is a limit for battery output/input. With zombieverter the battery is connected straight to the inverter. The car should move even with Battery regen/discharge power limit set to zero. ICE input welded of course. Am i right or not? If not then we need a car data dump from a car with Battery fault/disabled but driving. If the firmware locks it to max 52 mph then ICE rpm needs to be increased to fool the firmware into thinking its spinning. Or at least this is what I would do.
0tik wrote: Fri Aug 29, 2025 6:08 am Or at least this is what I would do.
What do you think all the talk in this thread of modifying the serial data was about?
Without an oem car and someone with the knowledge and hardware to capture logs all we can do is guess and modify the data.
