GS450H Solenoids SL1 SL2
catphish
Has thanked: 94 times
Been thanked: 179 times
Re: GS450H Solenoids SL1 SL2
Post by catphish »
PatrcioEV-ATX wrote: Wed Jul 26, 2023 3:51 pm I can't get the transmission to change to Low gear under any combination of these. Anyone have any thoughts?? I think SL2 always being HIGH no matter what I tell it is ok, but I don't understand why changing between TransSP HIGH and LOW has a different impact on PB1.
If all four combinations leave you in high gear, then you likely have a problem with your oil pressure. Is the oil pump running okay?
As far as I know, everyone else has been able to achieve low gear by setting both solenoids high with good oil pressure.
PatrcioEV-ATX
Has thanked: 40 times
Been thanked: 60 times
Post by PatrcioEV-ATX »
catphish wrote: Wed Jul 26, 2023 9:14 pm If all four combinations leave you in high gear, then you likely have a problem with your oil pressure. Is the oil pump running okay?
I have no slippage issues at all driving even under full throttle. I have the oil pump on a 60A breaker and if I forget to close it (sometimes I'll turn it off if I have the car on but am working on something), then I definitely can't move the car.
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
