Page 3 of 5
Re: Controlling an analog dash
Posted: Sun Jan 10, 2021 1:40 pm
by clanger9
With the power on, but the gauge input disconnected, try putting a 1k pull-up resistor between the gauge input terminal and +12v.
Does the gauge then return to zero?
Posted: Sun Jan 10, 2021 2:04 pm
by Greenbeast
Thanks clanger i will hopefully have a play with that this evening, and see if i get the same result as arber.
I think i need to improve my work bench setup, it's extremely Heath Robinson and not very conducive to good testing
Posted: Sun Jan 10, 2021 3:53 pm
I found an old schematic for my Mazda dial. It worked... I have to find one mosfet to tesxt this here...
See if you can get it to work.
Posted: Sun Jan 10, 2021 8:27 pm
by Greenbeast
clanger9 wrote: ↑Sun Jan 10, 2021 1:40 pm
Sorry, this does not appear to work.
arber333 wrote: ↑Sun Jan 10, 2021 3:53 pm
My gauge has +12V, GND and sender input, how should i interpret your diagram, should i assume the GND is a given, and connect it that way?
Is Q1 the mosfet?
Posted: Sun Jan 10, 2021 9:20 pm
by clanger9
When does the gauge go back down? Only when you disconnect the 12v supply?
Posted: Sun Jan 10, 2021 10:11 pm
Greenbeast wrote: ↑Sun Jan 10, 2021 8:27 pm
Is Q1 the mosfet?
GND is anywhere on the car i think. But you need 1K pullup for gate to invert signal and resistance toward GND so mosfet will pull signal down and release it in between pulses. What is your dial resistance on full and on empty?
A
Posted: Sun Jan 10, 2021 10:35 pm
by Greenbeast
clanger9 wrote: ↑Sun Jan 10, 2021 9:20 pm
Currently never, it stays up unpowered.
Posted: Sun Jan 10, 2021 10:40 pm
by Greenbeast
arber333 wrote: ↑Sun Jan 10, 2021 10:11 pm
Is Q1 the mosfet?
A
OK that doesn't mean much to me (I'm a relative novice).
I will check the service manual tomorrow to see if it details that. It shows the sender as 1-5Ohm full 104-117Ohm half full but oddly doesn't show the empty value, unless there's been a misprint (check my post on page 1)
Posted: Sun Jan 10, 2021 10:41 pm
Greenbeast wrote: ↑Sun Jan 10, 2021 10:35 pm
Hm... maybe there is damage to its internal circuit. Can you take the dash out and try to use the dial as ammeter? To confirm it still works?
Posted: Sun Jan 10, 2021 10:45 pm
Greenbeast wrote: ↑Sun Jan 10, 2021 10:40 pm
What car is this? European cars usualy have value somewhere around 10R(empty) 190R(full); US 240(empty) 30(full).
Posted: Mon Jan 11, 2021 8:15 am
by Greenbeast
Daihatsu Fourtrak, Japanese
Posted: Mon Jan 11, 2021 8:24 am
by Greenbeast
arber333 wrote: ↑Sun Jan 10, 2021 10:41 pm
That is entirely possible, i may have been a bit slap dash in my connecting and trying things out. Some of my warning lights don't work either now.
Thankfully this is a spare cluster
Posted: Mon Jan 11, 2021 1:16 pm
I have Mazda mx3 and it is in reverse of my EU Peugeot 406.
You should get a reaction if you connect 150R from signal towards GND.
Also verify if there is a fuse in that circuit. Maybe it is blown?
Posted: Mon Jan 11, 2021 9:20 pm
by Greenbeast
Ah, the mazda would be likely to match it i guess.
I can't see a fuse on the 'board', so unless it's inside the cluster i don't know.
Didn't have 150R, only a 91R, which did nothing. I need to get a few more components into stock
Posted: Thu Jan 14, 2021 6:28 pm
by Greenbeast
I tested the resistance across the terminals as suggested by the service manual and it reads higher than it should (70-80R, as opposed to 55R), the temp gauge reads correctly.
Posted: Fri Jan 29, 2021 4:24 pm
by Alibro
I just found this thread and I suspect it will be gold dust for me in the future so many thanks to all who have shared here. Very much appreciated.
Posted: Fri Jan 29, 2021 5:17 pm
by Greenbeast
I haven't pursued this much recently. Life got in the way. I was trying to set up a better bench rig for it. Breaking out the wires to a set of labelled screw terminals for easy testing, rather than a jumble of wires and loose crocodile clips
Posted: Sat Jan 30, 2021 7:31 am
by mackoffgrid
This is my solution to drive the instrument cluster in my ute conversion.
https://github.com/mackelec/SolarUte/tr ... s/CANio-18
It is all CAN bus driven - stm32Duino. It will drive the Temperature and Fuel gauges, various dash lights. The tacho is PWM driven (specific to the B2500 ute).
Posted: Sat Jan 30, 2021 9:14 am
by clanger9
Very nice! I may well use this for my bike project.
Posted: Sat Jan 30, 2021 10:41 am
by Greenbeast
Wow that looks cool! Thanks
Do you have any video content of this in situ working
Posted: Sat Jan 30, 2021 8:06 pm
by mackoffgrid
Thanks.
I've not done any videos - Never mind Cecil B Demille, I'm no Damian when it comes to video making
I'll see what I can do.
We're pretty slow in our project and while I made this board some time ago it's only now about to go into the car
Posted: Sat Jan 30, 2021 8:07 pm
by clanger9
My mind is blown by JLCPCB.
Literally: I just load those files in, click "SMT assembly", pay around $70 and I get 5x assembled boards in the post a few days later?
Is it really that simple?? That is incredible.
Posted: Sat Jan 30, 2021 8:44 pm
by Greenbeast
Does seem pretty cool.
I dare say i might take one off your hands at some point in the future
Posted: Sat Jan 30, 2021 10:46 pm
by mackoffgrid
clanger9 wrote: ↑Sat Jan 30, 2021 8:07 pm
I've been designing and drawing PCB's since crepe tape days
JLCPCB is truly remarkable from my perceptive.
I am now using their CAD, design a board, press a few buttons and a week later a man in a yellow van gives me assembled PCBs - Fantastic.
With some luck, Star Trek is our future !!!
Posted: Sat Jan 30, 2021 11:18 pm
by clanger9
Yep, last time I made a board it was paper tape, dunked in ferric chloride then hand-drilled. I had no idea that SMT boards were accessible to mere mortals. This changes *everything*
