Page 3 of 49
Posted: Thu Mar 18, 2021 9:19 am
by muehlpower
This is a very cheap CAN analizer. But I don't know if the format is compatible with savvy.
https://www.seeedstudio.com/USB-CAN-Ana ... -2888.html
The CAN BUS Analyzer Tool APGDT002 from Micrichip is more expensive but probably compatible. About 100€/$
Posted: Thu Mar 18, 2021 9:55 am
by Jack Bauer
I'm thinking more along the lines of something non pc based. just connect two wires and press a button. logs to an sd card.
Posted: Thu Mar 18, 2021 5:14 pm
by paaa
I have one of these for exactly that , and its just a reprogrammed olimax board
https://www.ebay.co.uk/itm/CAN-Bus-Data ... SwuOZeAQA6
Its great for quick on the fly logging, quick sniffing. I normally just import it I to excel sheet I have so it can convert hex and work out values that are made up of multiple bytes. Admittedly I do prefer the kvaser leaf light and savvy now though.
Posted: Fri Mar 19, 2021 12:54 pm
by Scott166
I wasn't sure how to put a video on so I have put a link to a vid of me trying to find the can cables.
https://photos.app.goo.gl/KksgtRfJR3v1NPRV7
Hope it works
Posted: Fri Mar 19, 2021 2:56 pm
by muehlpower
since it is an RHD the BDC will be on the left. The CAN BUS is also on the RND switch and instrument cluster. Twisted red and red / blue wire!
Posted: Fri Mar 19, 2021 3:27 pm
by Scott166
Posted: Mon Mar 22, 2021 2:36 pm
by Jack Bauer
Any progress folks?
Posted: Wed Mar 24, 2021 6:15 pm
by paaa
Im sending a usb can device to Scott with an inductive pickup so he can do some logging with savvy can on his car when charging.
Posted: Wed Mar 24, 2021 6:40 pm
by Jack Bauer
Excellent. Much appreciated.
Posted: Mon Apr 12, 2021 10:15 pm
by EV_Builder
paaa wrote: ↑Wed Mar 24, 2021 6:15 pm
Any news here?
I'm able to buy the device but offcourse i only want todo that if it makes sense
Posted: Tue Apr 13, 2021 6:47 pm
by paaa
Im hoping to test my setup on a few cars on work tomorrow, and then ship the unit to Scott on Thursday morning.
Posted: Tue Apr 13, 2021 8:55 pm
by EV_Builder
paaa wrote: ↑Tue Apr 13, 2021 6:47 pm
Owkidoki! Go Go Go Go!
Posted: Mon Apr 19, 2021 6:32 pm
by Hans Gustafsson
Here is a general Design_Guide of what needs to be done by a CCS port. I do not know if it is of any help to you, but here it is.
http://tesla.o.auroraobjects.eu/Design_ ... V3_1_1.pdf
Posted: Fri Apr 23, 2021 9:08 am
by Scott166
How's the Can gizmo going? Any luck yet?
Posted: Fri Apr 23, 2021 9:41 am
by paaa
I shipped it last week , it should be arriving soon.The joys of Brexit
Posted: Fri Apr 23, 2021 10:10 am
by Scott166
Excellent news, thanks
I hope it's not in the Suez
Posted: Fri Apr 23, 2021 1:49 pm
by Scott166
Posted: Fri Apr 23, 2021 1:50 pm
by Scott166
i think ive found it in the centre console
Posted: Fri Apr 23, 2021 1:51 pm
by Scott166
Is this going to be enough access?
Posted: Fri Apr 23, 2021 2:22 pm
by Bryson
The trick I’ve used in tight spots like that is to push a pin or needle into the wiring, then attach a clip to the bare needle sticking out. This should get you a signal without needing more than 10-20mm of wire access. Good luck and thank you!
Posted: Fri Apr 23, 2021 9:57 pm
by vwbrady
teach me how to run savvy can, i'll pull apart my i3 and go take some logs. I'm serious.
Posted: Fri Apr 23, 2021 10:54 pm
by mdrobnak
vwbrady wrote: ↑Fri Apr 23, 2021 9:57 pm
Windows, Mac, or Linux? What interface are you using?
-Matt
Posted: Sat Apr 24, 2021 1:41 am
by Bratitude
If you have a arduino due:
viewtopic.php?t=1425
that gets your can interface out of the way!
Posted: Sat Apr 24, 2021 2:11 pm
by vwbrady
mdrobnak wrote: ↑Fri Apr 23, 2021 10:54 pm
-Matt
Windows
Posted: Sat Apr 24, 2021 3:04 pm
by jon volk
vwbrady wrote: ↑Sat Apr 24, 2021 2:11 pm
-Matt
Windows
Just search YouTube for Savvycan. Collin has two or three tutorials
