MattsAwesomeStuff wrote: ↑Wed Jul 22, 2020 4:58 pm
I think you should give us a procedure of what you did. When troubleshooting, you can't just say what's broken, it's often helpful to tell us how you progressed. You won't know if you did something wrong (or you wouldn't have done it). Try to make it as easy for people to help you as possible.
Thanks for the advice, will try to keep it short.
BEFORE 'the problem' : I had 12V and GRND, LED PWR lit up and stayed ON and LED ALIVE flashed Red.
Communication via wifi - OK and web interface with values OK
Connected 2nd 12V supply for HV
Carried out Delta test with 3 X 21W light bulbs - one burnt brighter than the others but 1Hz flashing, solder joints maybe?
After playing with flslipspin and ampnom as per everyone helping here on the forum, I managed a spin up MG1 in Manual Mode from MG2 inverter output- Champagne!!
Connected standard 12V 20A relays for Precharge and Main contactors. Used a 3rd Relay ( IN and OUT switching circuit) to simulate precharge resitor - 40 Ohms. Precharge and Main contacter functioned correctly....
Connected 3 way position switch for Forward & Reverse - signal confirmed in values
Connected push button for STRT signal - OK
Connected MG2 inverter 12V signal to Forward and Reverse - thought MG2 ON signal is only required when direction is selected.
Connected Prius Gen 2 pedal - potnom would only activate from 90% to 100%, BUT communication via wifi still possible.
Wired up Resolver cabling (got it all wrong from what I see imwoody had done) along with Johu and what the rest of you posted, BUT, communication OK.
THEN : I had to leave my project a few days.....so when I returned, I decided to first clean up all my wiring.
I even anticipated higher HV, so connected 2nd series of more powerful relays, to be switched by the first set on original 12V Low voltage system.
Unable to get Precharge and Main contacters to function - No faults in web interface and Communication OK
4hrs later, went back to original relay set up. Unable to get Precharge and Main contacter to function correctly - Precharge remained ON permamnently. Put it down to bad connections and too many fuses all over the place.
Soldered up wiring and connected 12V supply and corresponding adapter board signals as before. Still only precharge relay staying ON.
All this time, LED Alive flashed and communication with board was OK.
THEN, I cut the precharge signal wire and denuded it for testing....I had 12V supply to the board connected.
When I moved the board for better testing position, the precharge signal wire (P16) 'fell' on the 12V supply I had close by....
Poof, and lights out was what happened next. LED PWR remains ON along with wifi adapter LED
Communication to wifi OK, web Interface communication is possible, but no values.
With a multimeter, I have confirmed at each through hole point that there is iether -3.3V, 5.5V or 0V.
Tested LED ALIVE with multimeter in diode Mode, doesn't beep, but I get the same with PWR LED. I do however get a resistance and then short circuit when testing in one of the directions. Confirmed PWR and ALIVE LED's values identicle...500 Ohm R32 resistor - OK
When GRND of multimeter on 0V 'reference' Q1 OUT_PRE and Q2 OUT_DCSW have 0v and 3.3V on each pins respectively.
How would I test the STM is not fried, or is there something else I should test before that?
I tried to reload parameters and reset web interface - no luck....
