Prius Gen 3 - 3D Printed Parts
bobby_come_lately
Has thanked: 56 times
Been thanked: 63 times
Re: Prius Gen 3 - 3D Printed Parts
Post by bobby_come_lately »
lukes wrote: Mon May 22, 2023 3:35 am Does anyone have drawings for the battery cable standoffs for use with battery_connector_v2?
Can't find that one on the github. Can you post a link to which one you mean?
lukes
Has thanked: 4 times
Post by lukes »
bobby_come_lately wrote: Mon May 22, 2023 6:49 am Can't find that one on the github. Can you post a link to which one you mean?
The brass ones that bring the battery connections outside the casing, as mentioned in this post (I think).
bobby_come_lately wrote: Mon Jun 22, 2020 12:55 pm
- Base plate should slot in to the rebate around the oval hole. The two brass *standoffs* then slot into this. I'm using threaded bar at the moment so I can thread these in to hold it all on while I do the rest. There's a space for an M6 threaded insert to screw the cover down but I'm still waiting on these for testing.
bobby_come_lately
3MF files OK?
Standoffs.zip
(409.18 KiB) Downloaded 122 times
lukes
Post by lukes »
bobby_come_lately wrote: Mon May 22, 2023 7:35 am 3MF files OK?
I'd prefer native 3d solids if you have them around, thank you
lukes
Post by lukes »
Never mind, I got off my lazy @$$. Here they are. For everyone's info, they are 19.8mm max diameter by 36mm (positive) or 46mm (negative) long. If anyone can make some for me (shipping to Michigan, US) DM me please
StandoffsCAD.zip
(7.24 KiB) Downloaded 151 times
bobby_come_lately
Damien was selling these but I don't think he is any more. Could be wrong though?
lukes
Post by lukes »
I reckon I found what you mean- http://www.evbmw.com/index.php/evbmw-we ... term-posts
It doesn't look like there's an option to add to cart like some of the other items, so you're right about Damien not selling it seems. If it's all bolted together anyhow, maybe stacking some standoffs from McMaster would do it. A little hacky, but what isn't these days?
bobby_come_lately
I'd guess you want as few mating surfaces as possible for moisture to get in to. I've also used off the shelf parts at other points - you can buy brass standoffs without the lip from ebay at different lengths. Be easy enough to mod the design?
lukes
Post by lukes »
I've been looking at those too, but most of the brass standoff sellers are across the pond from me. Is it important that they're brass? Off-the-shelf aluminum spacers are more easily available to me and I think aluminum is (surprisingly) more conductive than brass. I'd still be buying two different parts to make each standoff, a ~20mm OD and ~16mm OD section since I don't have a lathe.
