clanger9 wrote: ↑Mon Jun 15, 2020 2:31 pm
I've added an article to the wiki with some code that pulls data out of an IVT-S over CAN bus using an Arduino Uno.
Fabulous, thanks for sharing
Re: Isabellenhütte IVT-S shunts available
Posted: Fri Jun 19, 2020 3:02 pm
by james@N52E01
Success
Testing 12v 5a headlight bulb with IVT-S with Leaf VCU onboard WiFi
Posted: Fri Jun 19, 2020 3:19 pm
by Kevin Sharpe
james@N52E01 wrote: ↑Fri Jun 19, 2020 3:02 pm
Success
Well done, that's good news
Posted: Sat Jun 20, 2020 7:21 am
by james@N52E01
Here is a quick video on wiring the IVT-S shunt.
Part II will look at configuring the shunt using the Nissan Leaf VCU board.
Posted: Sat Jun 20, 2020 12:22 pm
by arturk
This is great video, very informative and nicely done!
I already have it working with GS450h VCU but cannot wait to watch "Part II"
Well done!
Posted: Wed Jun 24, 2020 1:53 pm
by james@N52E01
Here’s part 2 of the IVT-S configuration. My screen capture software didn’t like my video editing software so most of it is still frames.
Let me know if this has been useful and if you would like to see more tutorial videos.
Posted: Wed Jun 24, 2020 3:39 pm
by mdrobnak
I've only watched part of the last video, but knowing how much video editing effort alone...Bravo! Seems quite clear and easy to follow.
Thanks! I'll be referring back to this in a few weeks, I'm sure.
No kidding about those crimp connectors. My trick is to hold the terminal and switch the ratchet around to use the wider side to get a good crimp on just the outermost part that bites into the insulation. That way you can get the exact length of exposed wire you need and complete the innermost crimp at your leisure. (Honestly though I only recently noticed the crimp dies are uni-directional and have a wider crimp head for the outermost part)
Posted: Sat Jun 27, 2020 1:19 pm
by clanger9
I just noticed that the ISA library on EV-TV contains an error. ISA.cpp specifies #include <ISA2.h>, but the file is actually named ISA.h: http://media3.ev-tv.me/ISA.zip
The library from the EV-TV ISA.zip doesn't compile. The one from this site does.
There are multiple differences between the two libraries (although they look similar at first glance) - including the line in ISA.cpp that references either ISA2.h (EV-TV) or ISA.h (here)
Posted: Tue Oct 20, 2020 3:26 pm
by mdrobnak
Does anyone have a US source for the connectors for the shunt? Digikey and Mouser report 8-12 week lead times for those 4 pin connectors. I can get everything else immediately for like $6
-Matt
Posted: Tue Oct 20, 2020 5:11 pm
by jnsaff
I used tme.eu from Poland. They have them in stock but not sure they ship to states.
Posted: Tue Oct 20, 2020 5:21 pm
by jon volk
mdrobnak wrote: ↑Tue Oct 20, 2020 3:26 pm
-Matt
Probably quite a markup, but worth not waiting 2-3 months assuming there’s stock.
If you dont use octopart to search components, I suggest starting!
Posted: Tue Oct 20, 2020 11:06 pm
by mdrobnak
I totally forgot about Octopart. Attempting to cancel that order
Posted: Wed Oct 21, 2020 12:36 am
by mdrobnak
I just bought from RS Components (in the UK) and DigiKey - I think I got 5 sets for the price of 1 from that other place. Hopefully I was in time to cancel the order.
-Matt
Edit: Yay, order cancelled.
Posted: Thu Oct 22, 2020 1:58 pm
by jon volk
Ill take a set off your hands once they come if you dont need 5. Just let me know how much you'd want.
Posted: Fri Oct 30, 2020 11:47 am
by Bratitude
How much are we talkin here?
Posted: Fri Oct 30, 2020 3:57 pm
by mdrobnak
Oops, forgot this was the original spot I mentioned this.
Two things:
1. The 4 pin connector is _tiny_ and my 18 gauge wires are TOO BIG. so there's an issue when trying to use the retainer clip. I got it stuck for a few minutes connected to the shunt! It's fine without the retainer at least for the moment.
2. I totally missed the alternate part numbers list on the Wiki. So if you want everything from mouser, today, you can do that.
With that said, $8 + shipping (so like $12?) for US people I thought was reasonable. I'll know more concretely after running to the post office. I'll send a set out to Jon and follow-up with actual prices.
-Matt
Posted: Thu Jan 07, 2021 3:14 am
by gigawatts
Does anyone have any of these shunts available for sale? I am gathering parts for the Leaf VCU I just received =]
Posted: Thu Jan 07, 2021 11:33 am
by jnsaff
I might get my paws on a couple soon. Otherwise the manufacturer is selling them in multiples of 12. If we get enough takers I can put in another order. They are 165 EUR each including worldwide shipping (for multiples I can combine and get the shipping a bit cheaper).
Posted: Thu Jan 07, 2021 5:18 pm
by Bratitude
gigawatts wrote: ↑Thu Jan 07, 2021 3:14 am
