Page 2 of 2
Re: Good Enuff EV Wire Harnesses & Harness Kits
Posted: Tue Nov 18, 2025 9:19 pm
by cmon
Gregski wrote: Tue Jun 10, 2025 2:36 pm here I am thinning out a Lexus GS450h wire harness a customer sent me, this will eventually turn into a Kit for the Zombie VCU
slowly it's getting there, the vision is that you will receive everything except for the ZombieVerter VCU circuit board which you can obtain from EVBMW.com
this will be nicely loomed eventually
Bench Testing...
Hi - I already have the Lexus VCU board from this link: https://www.evbmw.com/index.php/evbmw-w ... gs450h-vcu
From your post it looks like you have a case - where did you buy this or is it 3D-printed?
Posted: Wed Nov 19, 2025 3:30 pm
by Gregski
cmon wrote: Tue Nov 18, 2025 9:19 pm Hi - I already have the Lexus VCU board from this link: https://www.evbmw.com/index.php/evbmw-w ... gs450h-vcu
Awesome, and I don't mean to be that guy, cause it took me like a year to find my way around all the documentation, but on that very page that you sent me the link of you will see the part numbers, and Damien the VCU maker recommends getting them from the Chinese eBay called AliExpress I would post direct links but they shuffle things around too much so just go there and do a search for these part numbers
the very bottom of the Wiki page on this very site has three different direct links you can try, AliExpress likes to give you [ahem] options for how little or how much you can get
Enclosure :
MPN: 5810130065
Mouser: 538-581-01-30-065
Description: Connector Accessory, Enclosure, Cinch ModICE SE Series Modular Connector Enclosures
Connector_BOM_GS450h.pdf
(34.29 KiB) Downloaded 30 times
there are links in the description of this YouTube video I posted as well
Posted: Wed Nov 19, 2025 5:53 pm
by Gregski
please forgive me for belaboring the point, but I think extracting the Lexus LS600h engine and transmission wire harnesses properly can safe some folks much grief, so here I am showing how the engine (ie inverter) harness on the left would have just plugged right in to the transmission (ie resolver) harness on the right with those white connectors
Posted: Wed Nov 19, 2025 7:16 pm
by danjulio
Nice to find a domestic enclosure that isn't insanely expensive (only pretty expensive)...
Posted: Thu Nov 20, 2025 5:35 pm
by cmon
I found molex igs files here in the forum for the case
https://openinverter.org/wiki/Mechanica ... n_database
https://github.com/bratindustries/molex-headers
- will testprint with ABS fillament this weekend and let you know - can share the *.stl just pm me if needed
Posted: Wed Dec 03, 2025 2:36 am
by Gregski
making progress on the LS600h harness, all the owner will have to do is buy his own Zombieverter VCU from Damien Maguire and screw it in to the housing that's provided, this harness will come pre wired for the Chevrolet Trailblazer hall effect throttle pedal (plug and pray style)
Posted: Thu Dec 11, 2025 4:47 pm
by Gregski
Good Enuff Garage now offering hall effect throttle pedals (mostly made of metal) for your EV Conversions, already pinned for the ZombieVerter VCU Built
the perfect stocking stuffer just in time for the Holidays - $75(ish)
Posted: Fri Dec 12, 2025 5:41 pm
by Gregski
so this is how that Lexus LS600h all wheel drive wire harness turned out, that the customer sent in to me to be "thinned out" yes I ran out of them printable nice sticky white labels so I just used blue tape to make sure every loose wire is labeled and tells him where it goes, I also didn't have enuff loom so I loomed what I could, normally these come unloomed cause I don't know how you will route them
something like this will run you: 3 goats, and 8 handfuls of salt
and here it is all installed:
Posted: Thu Jan 22, 2026 3:43 pm
by Gregski
came across this competitor wire harness kit for a Tesla, yes it is nice, but is it really 10 times better than mine, lol, don't answer that, just wanted you to see some [ahem] "options"
Posted: Sat Jan 31, 2026 8:32 pm
by Gregski
happy to offer pretty darn decent 2nd Gen Toyota Prius OEMish style throttle pedals and wire harnesses, compatible with the 3rd Gen Lexus GS450h throttle pedals as well, pinned and labeled for the Zombieverter VCU, just snap the pins into your Zombieverter header and calibrate away!
asking $80 (I know what I got, no low ballers! lol)
* actual products may slightly differ from pictures depending on parts scavengeability
Posted: Mon Feb 02, 2026 5:12 pm
by Gregski
continuing on with the Pedal To The Metal theme, it gives me great pleasure to now offer the OG - The BMW throttle pedal as seen on TV !
Posted: Tue Feb 03, 2026 2:02 pm
It's the GomeCat!!!
Posted: Sat Feb 07, 2026 3:51 pm
by Gregski
You did not ask for it, and I delivered:
Posted: Fri Feb 13, 2026 3:18 am
by Gregski
why don't you feast your eyes on The Good Enuff Garage's ever evolving flagship harness for the 2007-2011 Lexus GS450h rear wheel drive EV Conversions based on "Action Jack" Barker's Conjoined Triangle of Success
Posted: Sat Feb 14, 2026 4:33 pm
by Gregski
now that the Zombieverter supports PWM control for the EV Coolant pumps, Good Enuff Garage offers the OEM Lexus GS450h, Toyota Camry, and Nissan Altima style water pumps and harnesses
Posted: Sun Mar 29, 2026 9:29 pm
by Gregski
cranking out another Lexus GS450h wire harness (while quietly contemplating raising my prices... soon)
this one be having my favorite Honda Fit throttle pedal, we like it here at the Good Enuff Garage for it's metalabilities instead of being all plastic and such
this customer smartly opted to purchase the Zombieverter VCU with his wire harness so here I am kitchen table testing it for:
  • Zombieverting - ✔
  • WiFi-ing - ✔
