Leave out all the contactor stuff for now and connect the battery directly to have less room for errors.
FOC itself doesn't care about the voltage but udcsw and udcmin should be set to 0 for the first tests
Am I to dumb for Open Inverter
- Been thanked: 1918 times
Re: Am I to dumb for Open Inverter
Woohoo, Got the motor spinning today.
Thanks for the help!
waiting on my pins for the original plug to wire in my throttle and switches.
my set up was just a 50v bike battery on a nice contactor, a pre-charge resistor on a hand switch, a start switch,
used some jumpers to go between original plug and then used some more to get start switch and throttle inputs into the board
https://www.adafruit.com/product/1953
Had a little stuttering where it seemed like it was running away. Changed my minPot2 and seemed to help.
on to mechanical side for a while mating the motor to the transmission
