Have you spun the motor up yet? Would be interested to know what rpm/volt you're achieving before it's on the road.
Re: [DRIVING] BMW Z3
Posted: Fri Sep 29, 2023 7:08 pm
by andybpowell
Waiting for my zombieverter should arrive tomorrow
Posted: Fri Sep 29, 2023 7:59 pm
by andybpowell
It's only in the car so I can sort out the mounts and the propshaft then it's coming out so I can run it up on the bench,remove the selecter switch and lock the lever in position fit the loom and sort out any issues before it goes back in.
I also need to reposition my charger wiring under the car.
Posted: Sat Sep 30, 2023 8:02 pm
by andybpowell
Made up a template today for the front plate which will bolt to the lexus transmission as I'd rather mess up a cheap piece of mdf than an expensive ally plate, I made up some punches to the exact size to mark it through the bolt holes so that it's as accurate as possible
Also started making the steel work to fix it to the engine mounts, I'm using 3mm wall box section sadly I didn't get too far as I'm out of gas
Posted: Sun Oct 01, 2023 7:33 am
by Jacobsmess
I hate it when I run out of gas. I was doing some general repairs yesterday on my rust bucket *ahem* van, and ran out only to remember I have a very old cylinder of c02 that I was given knocking about.
It worked, but boy did it spit everywhere! Fortunately my welding is so messy it didn't look any better and/or worse than with argon.
Posted: Sun Oct 01, 2023 8:08 am
by andybpowell
Jacobsmess wrote: ↑Sun Oct 01, 2023 7:33 am
My welding varies wildly depending on how much practice I get My dad was a coded welder and taught me to weld but unless I weld regularly it goes down hill rapidly
Posted: Tue Oct 03, 2023 5:56 pm
by Jacobsmess
Not going to lie, the anticipation of hearing how your bench tests go is getting me scouring eBay and annoying breakers with emails again.....
Posted: Tue Oct 03, 2023 8:28 pm
by andybpowell
went to collect my connector for the inverter from lexus today only to discover they had ordered the wrong part, the part number on the wiki is
Plug: 90980-129922 but this is not a lexus/toyota part number as they need to be 5 + 5 digits and this is 5+6 so they just took one of the 9's out of the middle and didn't even tell me so i asked them to look to see if part no. 90980-12992 was the right part but they wouldn't even look without a reg no so
i won't be dealing with them again really unhelpful so if anyone actually has one maybe they could update the wiki
Posted: Wed Oct 04, 2023 6:58 am
by rstevens81
Sadly the dealers spares department are the most unhelpful breed of person out there, it's not just isolated to Toyota they all seem to be just as unhelpful. There's a reason why we will try every other avenue first. Both me and my wife own Toyota's however we have stopped taking them back for the recalls as they seem to break things every time they went in, the worst one they managed to loose the hands free parrot thing despite being attached to the dashboard.
I edited it to match (doubled checked with Damian's pic), btw you should also have wiki power if you login viewtopic.php?p=43421#p43421
I would go onto auto trader look for an is300h get it's reg then phone another evil Toyota garage.
Tbh I would be tempted to 3d print a blanking plate with a threaded hole for a gland and solder the wires that you need and have some cheap connectors outside, just to avoid going to Toyota again.
Posted: Wed Oct 04, 2023 7:35 am
by andybpowell
rstevens81 wrote: ↑Wed Oct 04, 2023 6:58 am
sorry didn't see damiens pic so couldn't edit the wiki as I wasn't sure what the part no. was, also don't have a 3d printer or any 3d cad skills but thanks for doing that
all of the information is here it's just finding it because there's just so much information
Posted: Wed Oct 04, 2023 7:41 am
by Jacobsmess
andybpowell wrote: ↑Wed Oct 04, 2023 7:35 am
I could probably model something in a car package but no 3d printer or inverter, so not sure if that's any help....
Re: [WIP] BMW Z3
Posted: Thu Oct 05, 2023 3:03 pm
by andybpowell
My Zombieverter arrived a while ago and now that the connectors and case have arrived I've got it all built up and tested and ready to go
The ally plate also arrived for the lexus transmission mount and to mount the coupler for locking the input shaft, this has had all of the mounting holes drilled using my template and I've finished the mounting to fix it to the engine mounts
now that's all done I can pull it back out again and get it up and running on the bench, I could possibly do what I need to do with it in place but experiance tells me it's not going to be that easy
Re: [WIP] BMW Z3
Posted: Fri Oct 06, 2023 7:44 pm
by andybpowell
The 300h transmission is back out of my Z3 now that all of the mountings are sorted and I've started to connect it to the inverter ready for testing
I have the original resolver wiring so that will make it simpler
Re: [WIP] BMW Z3
Posted: Mon Oct 09, 2023 11:05 am
by marcexec
andybpowell wrote: ↑Fri Oct 06, 2023 7:44 pm
Great progress! Where are you going to place the inverter?
Re: [WIP] BMW Z3
Posted: Mon Oct 09, 2023 2:45 pm
by andybpowell
marcexec wrote: ↑Mon Oct 09, 2023 11:05 am
I don't have an exact location yet but there's plenty of room under the bonnet
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 4:21 pm
by andybpowell
Ran the is300h L210 up today
getting shielded twisted pair cable for the serial connection to the inverter seems to be a problem no one wants to sell it in short lengths and a roll is expensive so I've cut the ends off of a cat7 patch cable which works really well as the pairs are individually shielded but it's very thin but I think I have a solution for that
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 4:34 pm
by Jacobsmess
Any chance of a max rpm at your supply voltage? Thanks!
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 4:38 pm
by andybpowell
It's not gonna be high it's only a 300w supply
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 4:47 pm
Wait so the Lexus hardware does not have a hardware under voltage limit, that opens up possibilities.
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 4:57 pm
by andybpowell
Had it running at 28v
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 5:04 pm
by Jacobsmess
Delete double post
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 5:20 pm
by Jacobsmess
Yeah I'm just wondering what the rpm/volt is, should hopefully be able to extrapolate up to a 400V max rpm, then I guess add a margin for field weakening but I don't really understand that...
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 7:07 pm
by andybpowell
Jacobsmess wrote: ↑Sat Oct 14, 2023 5:20 pm
I don't really understand So So many things but it doesn't stop me jumping in with both feet
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 7:52 pm
by rstevens81
I do understand what he said and you are doing the right thing ... There are so many variables involved that jumping in feet first really is the only option. Real world data always is better than analysis as there are always assumptions and simplifications.
Re: [WIP] BMW Z3
Posted: Sat Oct 14, 2023 7:57 pm
by Jacobsmess
Sure, but there's no harm in checking for rocks before jumping in, or at least asking the guy who jumped in before you whether there was anything to watch out for!
I guess the real thing I'm wanting to know is can I get away with an L210 transmission over the L110. It's cheaper, more reliable, smaller, lighter and simpler, the only problem is it's slower.
