Page 10 of 11
Re: [DRIVING] Leaf to VW Type 2 Campervan
Posted: Thu Aug 07, 2025 10:10 am
by ianlighting
I hearby change my project status to DRIVING (fully legal and in use)
Whoop!
Posted: Thu Aug 07, 2025 12:24 pm
by marcexec
Congratulations! A huge achievement for sure.
What's next?
Posted: Thu Aug 07, 2025 12:53 pm
by ianlighting
marcexec wrote: ↑Thu Aug 07, 2025 12:24 pm
What's next?
Ha! Well since you ask…
Still to do:
3d print DNR controls to match vw style knobs (thanks Cera)
Work out why I can’t get android auto to display leafspy using current Obd dongle
Fuel filler flap to house Chademo port
Engine bay sheet to fill open space around motor
Body work and interior upgrade.
Find alternative approach to noisy brake vac pump.
I have an idea to do some CANbus for some charging indications.
But if you mean, what’s the next project after this is all done, well the wife reckons I will do another one, but I suspect I’m on the hook first for finishing a load of other home related tasks instead of living in the garage. But if I did… it would be something from the 50s to the 70s. Possibly another vw, but maybe not. And maybe I’d take my learnings and take another step down the rabbit hole with zombie etc. but I haven’t thought about it. At all. Honest…
Posted: Thu Aug 07, 2025 11:11 pm
by jerrykco
Congratulations!
Posted: Fri Aug 08, 2025 10:59 am
by marcexec
iBooster for the brakes if you can mount one?
https://openinverter.org/wiki/Bosch_iBooster has a good few options nowadays and I'm advertising the page elsewhere, too.
Posted: Fri Aug 08, 2025 11:19 am
by ianlighting
Yeah, I know of them. And Cera’s T2 build used one that she wrote up, and I know Brat Industries has written up a how to on them aswell. So no excuses - just got to engage brain.
Although another approach came from Electric Classic Cars (YouTube). Their last split screen camper conversions, they told me don’t use either a vac pump or booster. Just upgraded brakes are good enough apparently - they use wilwood. So just what I need - more options…
Posted: Tue Aug 12, 2025 12:07 am
by PEDR0
Nice work, must be a great feeling when the logbook lands on the door mat
Re: [FIRST DRIVE] Leaf to VW Type 2 Campervan
Posted: Tue Aug 12, 2025 5:05 am
by alexbeatle
ianlighting wrote: ↑Wed Jul 30, 2025 2:04 pm
Old radiator didn’t cut it when it got 30 degrees outside recently, so I’ve upgraded to a super widescreen version.
I’ll see how it copes with just my 2 fans, but there’s space to add another at each end if it needs more blow. Actually it’s suck so the air goes the same direction when moving.
Hi. Do you find it to cool sufficiently?
Posted: Tue Aug 12, 2025 5:40 am
by ianlighting
PEDR0 wrote: ↑Tue Aug 12, 2025 12:07 am
Yep - mainly because if you decide the target is to become all official and legal, you know you are putting yourself in the hands of a obscure bureaucratic process that you may get wrong and be unable to resolve. So would have been v upsetting after months of work if they declined!
Posted: Tue Aug 12, 2025 5:43 am
by ianlighting
alexbeatle wrote: ↑Tue Aug 12, 2025 5:05 am
Haven’t done a proper road test yet. Expect an update next week. We’re off to another festival 90 minutes away on Friday with 30 deg temps predicted again, so a good comparison test with my last trip.
Posted: Tue Aug 12, 2025 11:03 am
by PEDR0
Good test for the new rad
Posted: Mon Aug 18, 2025 4:43 pm
by ianlighting
So now the engine / motor bay has an aluminium sheet installed. Intention is to reduce road water from getting into the bay to reduce risk of a 12v short. Plus it’s linked to the discussion I had with Terry about cooling.
Travelled on Friday about 70 miles, outside temp about 28 deg C. Generally the reported motor (incl PDM and inverter) coolant temp was in the 50s - 60s. Probably obvious to say this, but driving through a sequence of roundabouts on a section of dual carriageway generated the most heat due to the hard regen braking followed by fast acceleration, and then repeated multiple times shortly after. That had a peak of 75, but it quickly dropped back into the 60s.
I think my conclusion is the bigger radiator dissipated the heat more rapidly! No shit!
As to the effect of the aluminium sheet. Can’t really be conclusive, but I’m glad it’s there just to keep debris and wet out of the bay.
In a nod to the comments from Terry, since I had to make the cut out shape in the sheet larger in order to wiggle it into the awkward space around the motor, most of that extra wiggle space I put toward the rear, so that any positive air pressure from the T2s side scoops might get pushed down through that gap over the radiator below. Not possible to tell if that has any effect, but that’s the intention.
Worth noting the VCU turns on the fan at 60 degrees. Not configurable, so potentially I could divorce the fan control to a separate isolated circuit to have it come on at lower temps.
I’ll continue to have my co-pilot read out temperatures on long hot journeys to check how it behaves, but I suspect I’m parking this item now until next summer.
Posted: Mon Aug 18, 2025 6:50 pm
by WillK
Very tidy!
Posted: Sun Nov 16, 2025 5:02 pm
by alexbeatle
Hi. I’m curious, what is your setup for defogging/defrosting front windshield?
Posted: Sun Nov 16, 2025 5:19 pm
by ianlighting
alexbeatle wrote: ↑Sun Nov 16, 2025 5:02 pm
Ha! Funny
Currently zero solution, but maybe I’ll get to that. I guess since it’s mainly a summertime vehicle it’s less of a routine problem for me than if it was a daily driver. It’s all been on a slight back burner for me recently, but have a huge list of stuff to do probably in the new year. Currently no heat source in there, so need to think about it.
Posted: Sat Jan 10, 2026 5:42 pm
by ianlighting
Right then, my next priority jobs in no particular order…
Sort out my dashboard. I can 3D print the controls I need, but have some styling decisions to make first.
Mount Chademo port to my outside fuel flap. Should be doable, but need to extend HV cables.
Brake Ibooster - I really can’t stand my vac pump noise anymore.
I’ve used the model list from EV Create and gone cross eyed opening countless tabs on eBay. Think what I’m after is the Renault Zoe flavour because it seems to be the only variant that has a small mounted fluid container, plus a tube to a 2nd remote container, which is an arrangement that works best for the VW.
But it’s slightly frustrating finding one that includes the large plug, most of the UK sellers don’t include it. European sellers, mainly Lithuania for some reason are much better at including it. But then there’s more postage!
I’m looking all shiny now… (and the van’s not bad either!)
Posted: Sun Jan 11, 2026 3:47 pm
by marcexec
We have extended on the original list a bit:
https://openinverter.org/wiki/Bosch_iBooster, BTW the Zoe needs a CAN connection.
Posted: Sun Jan 11, 2026 3:57 pm
by jerrykco
ianlighting wrote: ↑Sat Jan 10, 2026 5:42 pm
Looking very nice indeed!
Posted: Sun Jan 11, 2026 4:16 pm
by ianlighting
Ah! Thanks for that detail. CAN wasn’t in my plans right now. I’d wanted to just use the basic 12v only mode. In which case I can probably find a cheaper unit than the one I was looking at but will then need to work out a solution for the remote reservoir.
i don’t have any experience of fitting separate after market reservoirs so don’t know how well they can be expected to fit. Pretty sure leaky reservoirs would be a bad thing.
Posted: Tue Jan 13, 2026 12:13 pm
by ianlighting
I now own a Renault Arkana ibooster. Never heard of an Arkana.
At £56 incl delivery I thought it was worth a punt. Marc helpfully told me that the Renault Zoe version needs CAN ack, so I realise this could be the same as it’s the same make. So I’ll just have to work that out if that’s how it turns out.
Posted: Tue Jan 13, 2026 1:35 pm
by Jacobsmess
I'd expect so re: CAN ack but implementing something should be pretty simple. An ESP32 with can transceiver and CAN H and L would do it... or even wiring it into your current setup if there is some CAN H and L wires for comms would work. Just have to check for termination and that there's no issues with CAN conflicts
Posted: Tue Jan 13, 2026 3:04 pm
by ianlighting
Did a basic test today.
Didn’t travel anywhere, just turned the van on, put new LED headlights on full high beam. Came back 4 hours later.
LeafSpy said I started on 95.7% / 167.03Ah. End on 95.2% / 166.10.
Also running was the coolant pump and brake vac pump. And traditional rear light filament bulbs.
I could have worked it out, but nice to see for real that energy consumption is so low.
Posted: Thu Jan 15, 2026 5:52 pm
by ianlighting
Wired up the Renault Arkana Gen2 ibooster for a bench test. Seems to work. As suspected it does require CAN or it won’t move. Used pins 16 and 25 for CAN in addition to the other standard pins for basic mode as shown in the EV Create guide.
Posted: Fri Jan 16, 2026 12:18 pm
by Jacobsmess
Could you also populate the Arkana entry on the table here?
Or post the data/photos and I can, cheers
Posted: Fri Jan 16, 2026 12:20 pm
by ianlighting
Its already in there, but yes I'll update the existing entry. I'll probably wait until I have it fully installed and working to avoid misleading anyone before its proven.
