The library and demo code I sent Kevin, which he linked above, compiles, loads and works. I have 5 isa shunts in cars working with this now and the last time I had any formal software training we were using wire wrap boards!
#ifndef ISA2_h
What could that mean? hmmm....if ..not...defined.....ISA2_h...
#define ISA2_h
Define it as ...ISA2_h
Its a friggin trick question! in english it would read as "If my name is not Damien, Make my name Damien"
Re: Isabellenhütte IVT-S shunts available
Posted: Mon Jun 08, 2020 9:50 am
by james@N52E01
Thanks JB, sorry for wasting your time there.
As Kevin say, the demo file loads up and runs fine on the VCU board. A quick look at the code shows that the “i” command through the serial monitor should initialise the shunt.
Posted: Mon Jun 08, 2020 5:02 pm
by clanger9
Is ISAScale_Test_dm2.ino for a Due board only?
I've got my Isabellenhütte working great with an Uno + cheap CanBUS shield. I will post details on the wiki.
I don't have a Due (yet).
Posted: Fri Jun 12, 2020 10:33 am
by Kevin Sharpe
Testing the ISA shunt through the Leaf VCU board with a 12v 5a headlight bulb
I'll add something similar for a Due when I have the necessary transceiver...
Posted: Mon Jun 15, 2020 2:34 pm
by Kevin Sharpe
clanger9 wrote: ↑Mon Jun 15, 2020 2:31 pm
I've added an article to the wiki with some code that pulls data out of an IVT-S over CAN bus using an Arduino Uno.
Fabulous, thanks for sharing
Posted: Fri Jun 19, 2020 3:02 pm
by james@N52E01
Success
Testing 12v 5a headlight bulb with IVT-S with Leaf VCU onboard WiFi
Posted: Fri Jun 19, 2020 3:19 pm
by Kevin Sharpe
james@N52E01 wrote: ↑Fri Jun 19, 2020 3:02 pm
Success
Well done, that's good news
Posted: Sat Jun 20, 2020 7:21 am
by james@N52E01
Here is a quick video on wiring the IVT-S shunt.
Part II will look at configuring the shunt using the Nissan Leaf VCU board.
Posted: Sat Jun 20, 2020 12:22 pm
by arturk
This is great video, very informative and nicely done!
I already have it working with GS450h VCU but cannot wait to watch "Part II"
Well done!
Posted: Wed Jun 24, 2020 1:53 pm
by james@N52E01
Here’s part 2 of the IVT-S configuration. My screen capture software didn’t like my video editing software so most of it is still frames.
Let me know if this has been useful and if you would like to see more tutorial videos.
Posted: Wed Jun 24, 2020 3:39 pm
by mdrobnak
I've only watched part of the last video, but knowing how much video editing effort alone...Bravo! Seems quite clear and easy to follow.
Thanks! I'll be referring back to this in a few weeks, I'm sure.
No kidding about those crimp connectors. My trick is to hold the terminal and switch the ratchet around to use the wider side to get a good crimp on just the outermost part that bites into the insulation. That way you can get the exact length of exposed wire you need and complete the innermost crimp at your leisure. (Honestly though I only recently noticed the crimp dies are uni-directional and have a wider crimp head for the outermost part)
Posted: Sat Jun 27, 2020 1:19 pm
by clanger9
I just noticed that the ISA library on EV-TV contains an error. ISA.cpp specifies #include <ISA2.h>, but the file is actually named ISA.h: http://media3.ev-tv.me/ISA.zip
The library from the EV-TV ISA.zip doesn't compile. The one from this site does.
There are multiple differences between the two libraries (although they look similar at first glance) - including the line in ISA.cpp that references either ISA2.h (EV-TV) or ISA.h (here)
Posted: Tue Oct 20, 2020 3:26 pm
by mdrobnak
Does anyone have a US source for the connectors for the shunt? Digikey and Mouser report 8-12 week lead times for those 4 pin connectors. I can get everything else immediately for like $6
-Matt
Posted: Tue Oct 20, 2020 5:11 pm
by jnsaff
I used tme.eu from Poland. They have them in stock but not sure they ship to states.
Posted: Tue Oct 20, 2020 5:21 pm
by jon volk
mdrobnak wrote: ↑Tue Oct 20, 2020 3:26 pm
-Matt
Probably quite a markup, but worth not waiting 2-3 months assuming there’s stock.
If you dont use octopart to search components, I suggest starting!
Posted: Tue Oct 20, 2020 11:06 pm
by mdrobnak
I totally forgot about Octopart. Attempting to cancel that order
Posted: Wed Oct 21, 2020 12:36 am
by mdrobnak
I just bought from RS Components (in the UK) and DigiKey - I think I got 5 sets for the price of 1 from that other place. Hopefully I was in time to cancel the order.
-Matt
Edit: Yay, order cancelled.
Posted: Thu Oct 22, 2020 1:58 pm
by jon volk
Ill take a set off your hands once they come if you dont need 5. Just let me know how much you'd want.
