Page 8 of 8
Re: Nissan Leaf BMS
Posted: Sun Feb 16, 2025 9:49 pm
by maiks
Marat wrote: ↑Fri May 31, 2024 7:20 pm
I modified the firmware of the BMS unit of all generations of Liaf, chip 70F3236 70F3382, in order to expand the range of their operation to the required battery parameters, the most popular CATL 115Ah 120Ah 180Ah..., there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp).
hello ,
Thanks for sharing . Am kindly requesting for 63kw firmware or a link where l can download it
Re: Nissan Leaf BMS
Posted: Mon Feb 17, 2025 7:45 am
by Marat
You can only purchase a pre-programmed LBC module of all Leaf(Gen1-Gen3), with a pre-agreed battery power, the price is the average price of LBC + $150.
Re: Nissan Leaf BMS
Posted: Tue Feb 18, 2025 8:37 am
by maiks
Marat wrote: ↑Mon Feb 17, 2025 7:45 am
I have a 30kW BMS. Would it be possible for me to send it to you for an upgrade to 64kW?
Re: Nissan Leaf BMS
Posted: Tue Feb 18, 2025 3:38 pm
by Marat
send PM
Re: Nissan Leaf BMS
Posted: Thu Jun 19, 2025 6:23 pm
by ginetto
FYI current sensor pinout for 62kWh nissan leaf BMS is different from that used for 40kWh.
I measured the continuity directly from current sensor harness to the bms harness. Note. in the middle there is another harness entering in the junction box where the current sensor is located.
the result pinout is:
1->10
2->9
3->15
4->11
Re: Nissan Leaf BMS
Posted: Sun Aug 17, 2025 1:39 pm
by ginetto
Hi, I'm interested in this firmware, how to proceed? I've a 63kWh catl setup and different BMS . the idea is to run it in ZE1 model.
let me know
regards,
Luigi
