PowerWatcher Display for Tesla
Has thanked: 329 times
Been thanked: 847 times
Re: PowerWatcher Display for Tesla
You could always use the Zero EV can messages for the DU as a base.
Currently populated two messages with the following
Been thanked: 1122 times
Thanks Tom. I'll use that as a template.
Ok then here is a stripped down DBC attached, also has the base Can info for SimpBMS and the open source Tesla Charger. I removed some info I received in confidentially.
Cannot upload '.dbc' that is why it is rar'ed
zeroev - Copy.rar
(1.24 KiB) Downloaded 442 times
New webshop for Powerwatcher products :
https://shop.emkit.net/shop
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
Looks interesting.
I just looked at his power watcher 3 high voltage,
Max voltage 200v
Is this correct ?
Where did you see 200v for the powerwatcher 3? powerwatcher 2 was limited to 200v NOT powerwatcher 3. powerwatcher 3 can go to 450v.
jon volk
Post by jon volk »
Jack Bauer wrote: Mon Oct 14, 2019 7:45 pm New webshop for Powerwatcher products :
Just to confirm, the high voltage V3 kit currently in the webshop is ready to go for Telsa LDU compatibility, assuming the proper CAN messages are loaded?
Igor
Has thanked: 20 times
Post by Igor »
The webshop lists two different powerwatcher 3 kits. The lower priced "middle voltage kit" looks like it's limited to 200v.
@jon volk no not yet. Seeing as no one wants to bother making a list of can commands for Yuriy it's waiting on me.
What can commands are you after? As I provided an dbc on the previous page for certain parameters.
Right so based on Tom's dbc I have attempted to make a human readable CAN spec which is attached. I think it captures most of the items we would care to have on a display. Powerwatercher should be able to do the maths to get road speed from motor rpm and tyre size. It already has this facility for analog speed input. Let me know if I've missed anything.
DU_CAN_V1.pdf
(25.36 KiB) Downloaded 396 times
Attached amended version following some feedback from Yuriy. He has confirmed vehicle speed from motor rpm will be supported.
Powerwatcher V3 can go up to 600vDC. I have asked him to update his website to reflect this as I could buy a Model 3 if I had a euro for everyone asking this:)
DU_CAN_V2.pdf
(25.85 KiB) Downloaded 289 times
aaannnnd the final version:) Temperature now 1 bit per deg C and signed.
DU_CAN_V3.pdf
(26.14 KiB) Downloaded 344 times
jon volk
Post by jon volk »
Does the below look correct for translating the .pdf of standards into values that get plugged into the software?
IDC= 309, 0, 16, .1
UDC= 309, 16, 16, .1
UAUX= 309, 32, 8, .1
DIN_OCUR= 309, 40, 1, 1
IAC= 309, 48, 16, .1
OPMODE= 310, 0, 4, 1
DIR= 310, 8, 4, 1
SPEED= 310, 24, 16, 1
TMPHS= 310, 48, 8, 1
TMPM= 310, 56, 8, 1
joromy
Post by joromy »
Have put it in the Wiki.
Would recommend to not shorten any values in the CAN messages, that are coded in the inverter hardware.
Better to shorten in the receiving end.
jon volk
Post by jon volk »
So, you're saying just leave the gain fields at 1 and just manipulate the data in the receiving code?
joromy
Post by joromy »
That to, but was more referring to the motor and HS temp they are 16bit resolution in code.
I think is good practice to have it same as the programmer intended.....
I don't know the reason for having so high resolution, only the programmer knows.
The point is to have a defined CAN standard, not exactly the way I want it :)
Good to have some input and suggestions.
jon volk
Post by jon volk »
Ahhhh got it. I wasn't sure if that was directed at my post or the parameters in general.
Just to update on this I now have the hardware and software for testing this with the Tesla drive unit. Just not had time to do so as yet.
bulletbug
Post by bulletbug »
I've got the basic high voltage hardware from PowerWatcher. I'm not far enough with my first build to have it up and running yet but I'm definitely interested in seeing what type of customization will be possible for displays. I'm hoping that I'll be able to pickoff the data being reported and display it within a graphic that I set up. I'm working on converting a 69 VW beetle, and would love to replace the speedo with a digital version that looks like the original with the extra fields on information like WH, consumption and "fuel gauge".
Roadstercycle
Post by Roadstercycle »
jon volk wrote: Mon Feb 24, 2020 3:56 pm Ahhhh got it. I wasn't sure if that was directed at my post or the parameters in general.
Jon, Did you get your power watcher up and running?
jon volk
Post by jon volk »
Roadstercycle wrote: Sat Sep 05, 2020 11:32 pm
Never went that route. Working on a web-Bluetooth display instead.
Roadstercycle
Hopefully a new thread on that sometime. I'm interested and curious.
