Page 7 of 8
Re: Nissan Leaf BMS
Posted: Mon Aug 28, 2023 12:36 pm
by janosch
shuma89 wrote: Sun Aug 27, 2023 8:54 pm I changed only batteries, not BMS or other parts in battery box.
It sounds like you did a 40kWh upgrade? Surprised the 40kWh cells fit into the 24kWh box without changes.
Best forum member to talk to is dala https://dalasevrepair.fi/
I think you will need:
  • 40kWh BMS
  • dalas 40 -> 24 CAN bridge
and with that fitted the Leaf should understand the bigger battery.
Re: Nissan Leaf BMS
Posted: Fri Apr 26, 2024 6:36 pm
by Jacobsmess
Ok, so anyone got a TLDR; for how to use the leaf BMS from a 40kWh pack? One arrived today, I suspect I'm going to have to do some digging. I've read a lot so far but nothing super conclusive for my tired brain.
Can I just hook up 12V, Gnd, CanH and CanL and get data via a Bluetooth dongle and leafspy lite? Is there some documentation on which cells connect where on the BMS cabling?
Re: Nissan Leaf BMS
Posted: Fri Apr 26, 2024 8:39 pm
by Jacobsmess
evcar wrote: Fri Jan 17, 2020 6:11 am I 've attached the wiring diagram from the 2013 BMS that I used in my car.
Ok so this is a great start for wiring things up, although interestingly my LS11 connector has an extra wire that's not shown on this diagram on pin 11.
Re: Nissan Leaf BMS
by Jacobsmess
From Cor @ DIYElectricCar wrote: The BMS cannot limit anything, it only measures voltage and current and it will balance the cells 24/7 as long as it receives +12V on pin 5 (BAT) of the round connector, which is wired to pin 12 of the LB11 connector.
Also, all 96 pairs of cells need to be plugged in obviously.
The BMS will only communicate when there is 12V on either IGN (pin 4 round connector, pin 6 or 7 of LB11, for old/new BMS) or CHG IGN (Charging) which is located on pin 21 or 31 (old/new battery type), pin 5 of LB11.
Source: https://www.diyelectriccar.com/threads/ ... ost-871641
Re: Nissan Leaf BMS
Posted: Sat Apr 27, 2024 7:33 am
by Jacobsmess
A question, will the BMS report voltage for just 1 cell for testing purposes? It would be nice to have it setup spitting out CAN and then connect cells one by one and see the voltages show up on leaf spy.
Re: Nissan Leaf BMS
Posted: Sat Apr 27, 2024 7:59 am
No, all cells must be connected
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 5:47 am
by ianlighting
I am considering getting new CATL modules for a project that is based on Nissan Leaf and Resolve EV. These would be 4s1p x24 modules and total 63kWh.
Are there any options for getting hold of a Leaf 62kWh BMS? I don’t want to buy an entire second hand battery pack.
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 6:54 am
by Jacobsmess
ianlighting wrote: Thu May 30, 2024 5:47 am I am considering getting new CATL modules for a project that is based on Nissan Leaf and Resolve EV. These would be 4s1p x24 modules and total 63kWh.
They come up on eBay from time to time. I'm not sure the 62kwh pack has been reversed engineered but I think a 24kwh or 36kwh BMS should work fine. The 42kwh is a little more tricky apparently
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 7:01 am
by ianlighting
Jacobsmess wrote: Thu May 30, 2024 6:54 am They come up on eBay from time to time. I'm not sure the 62kwh pack has been reversed engineered but I think a 24kwh or 36kwh BMS should work fine. The 42kwh is a little more tricky apparently
I have 24kWh BMS. So to be clear, it should work ok with the larger capacity if wired correctly? That’s good info, thanks. If it’s at least worth a go I will get into it in due course.
I did look on eBay. I have seen 1x 62kWh complete battery pack for £8800! No thanks :) but no separate BMS. So reusing my spare 24KWh would be a good option. I had assumed they were matched to the factory shipped model / capacity.
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 7:13 am
by Jacobsmess
ianlighting wrote: Thu May 30, 2024 7:01 am I have 24kWh BMS. So to be clear, it should work ok with the larger capacity if wired correctly?
I believe so. Alibro here has used the 24kWk leaf BMS with VW modules. You may need to reinterpret the messages with an Arduino or something similar but I'm a bit out of my depth from here on.
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 7:16 am
by ianlighting
Jacobsmess wrote: Thu May 30, 2024 7:13 am I believe so. Alibro here has used the 24kWk leaf BMS with VW modules. You may need to reinterpret the messages with an Arduino or something similar but I'm a bit out of my depth from here on.
Well I’ll report back if I’m successful. Or not….!
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 7:24 am
by Marat
Reprogramming the unit is necessary, otherwise the factory firmware will only process 22KWh, and this is in the case of a wear data reset.
BMS 40KW sees a maximum of 115Ah, and requires a different current sensor.
Re: Nissan Leaf BMS
Posted: Thu May 30, 2024 7:30 am
by ianlighting
Marat wrote: Thu May 30, 2024 7:24 am Reprogramming the unit is necessary, otherwise the factory firmware will only process 22KWh, and this is in the case of a wear data reset.
Ah, ok. That’s sounds more like what I expected, even though I am coming from a pretty low-knowledge starting point, so I am deferring to those with more experience at this stage.
I doubt I am able to reprogram the Leaf BMS. Unless there are methods that others have used previously that can be easily followed?
If not, that takes me back to the starting point of needing a factory built 62kWh BMS, which I expect will be hard to find.
I’ll keep poking about to see what options exist for my project. I’ll dig into what was referred to with @alibro”s project to see if that’s an option.
More inputs welcome :)
Re: Nissan Leaf BMS
Posted: Fri May 31, 2024 11:35 am
by Jacobsmess
I've not heard anywhere that states the need for reprogramming on any thread on the leaf BMS when I was looking into it. Do you have more information on this?
Re: Nissan Leaf BMS
Posted: Fri May 31, 2024 7:20 pm
by Marat
I modified the firmware of the BMS unit of all generations of Liaf, chip 70F3236 70F3382, in order to expand the range of their operation to the required battery parameters, the most popular CATL 115Ah 120Ah 180Ah..., there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp).
Re: Nissan Leaf BMS
Posted: Fri May 31, 2024 8:31 pm
by ianlighting
Marat wrote: Fri May 31, 2024 7:20 pm I modified the firmware of the BMS unit of all generations of Liaf, chip 70F3236 70F3382, in order to expand the range of their operation to the required battery parameters, the most popular CATL 115Ah 120Ah 180Ah..., there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp).
You have skills and knowledge that I don’t have unfortunately!
I don’t know exact what my requirements will be, I am still getting there. But when I do know, would you be interested in modifying my BMS from a 24kWh to work with what I decide on? I could post it to you, with return packaging included, plus whatever form of appreciation we agreed on.
Re: Nissan Leaf BMS
Posted: Wed Jul 31, 2024 12:23 am
by noelho
Is it possible to change firmware and the sensor on a 24kWh BMS so that it can see a larger 62kWh pack?
Re: Nissan Leaf BMS
Posted: Wed Jul 31, 2024 12:52 am
by noelho
How do you modify the firmware of the BMS?
Re: Nissan Leaf BMS
Posted: Wed Jul 31, 2024 9:40 am
by Marat
The 24 kWh BMS current sensor does not need to be changed, only the software is changed.
Unfortunately, it is almost impossible to do this now (RU).
Re: Nissan Leaf BMS
Posted: Thu Aug 01, 2024 12:21 pm
by christoph
Does anyone have the part numbers of the connectors needed for the BMS? The part number in the wiki page seem to be the ones further apart on the wiring harness. I'm especially searching for the connectors for LB13 and LB14.
Re: Nissan Leaf BMS
Posted: Mon Aug 05, 2024 10:07 pm
by noelho
Marat wrote: Wed Jul 31, 2024 9:40 am The 24 kWh BMS current sensor does not need to be changed, only the software is changed.
Impossible to change the software now? How come?
Re: Nissan Leaf BMS
Posted: Sat Oct 26, 2024 9:24 pm
by ramdoor
Hi Marat,
I'm interested in flashing the Leaf BMS. Can you help with that?
Re: Nissan Leaf BMS
Posted: Fri Nov 08, 2024 10:20 pm
by mcb
I would also like to use the leaf BMS with bigger and new cells, from a diffrent car.
Marat, or anyone else with the knowledge, could you please descripe how to modify the leaf BMS (which hardware and software is needed to do so)?
I dont understand this: "there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp)". Where is the example? How can I get the needed files? Which hardware and software is needed to modify the BMS?
Thanks in advance.
Mike
Re: Nissan Leaf BMS
Posted: Wed Jan 08, 2025 2:27 am
by Bratitude
mcb wrote: Fri Nov 08, 2024 10:20 pm Hi,
Thanks in advance.
Mike
Re: Nissan Leaf BMS
Posted: Wed Jan 08, 2025 9:05 pm
by mcb
Hi Bratitude,
thanks a lot for this!
