Re: [WIP] Voltswagen T2 -76
Posted: Sun Apr 13, 2025 7:30 am
That or maybe bus bar your way out. Towards the middle of the motor, then cables?
openinverter Community
https://openinverter.org:443/forum/
Good call. Lost my brakes already because of the inline sensor failure . Installed a mechanical switch on the pedal instead (end of the video).
Thanks for the heads-up! I'll probably end up doing a sort of floor/thin weathershield panel covering the empty area around the motor to keep the motorbay a bit dryer in general. We'll see.
Ahhh this is so perfect. Thanks a lot for the info! I had thought iBooster must have some output which would make the cleanest of solutions, but didn't find any info except people reverse engineering the canbus which I don't (yet) understand at all. I'll surely take another look at that.WillK wrote: βFri Jun 13, 2025 8:07 am I think you should be able to use one of the pins on the iBooster for brake lights.
Pin 24 is "brake sys monitor" which in my testing goes 0V-12V when pressure/movement applied to the push rod.
Loving this build. Would you be willing to share the 3d files of the motor mount?
I think I'll be doing Tesla M3 motor in my camper, but your detailed modelling of the engine mounts would be invaluable. Thanks
Oh! Hey yes that's pretty much exactly what I had in mind!J0hannes wrote: βThu Jun 26, 2025 2:41 pm Simpsons did it
As this is basically a reiteration of something that exists, why not take a look how one implementation has been made and see how to adapt/improve the design from there?
https://inductiveauto.com/product/nissa ... 25VsPEtW-K
As Cera is from Finland, I don't see an issue on the emi as current rules for conversion don't really ask much regarding that if the vehicle being converted is old as this Voltswagen is.
Yes adding spacers like this between the wires sounds good. I might just steal the idea of using those threaded cable passthroughs used in the linked product for waterproof connections.jrbe wrote: βThu Jun 26, 2025 11:56 am This is what pops into my head I drew the phase wire section a bit too tall, keep it short but effective to not get into vibration induced fatigue / failure where it overhangs. If you get the spacing right you could use a silicone to seal the wires to the adapter & cover.
Of course! I'll see what I can doJacobsmess wrote: βThu Jun 26, 2025 11:27 am I'll let others comment on the safety, but if you do this I'd be interested in a similar setup if you're happy to sell one on? Thanks
Yes I saw thatianlighting wrote: βFri Jun 27, 2025 5:04 am Did you see what @Windraver did for this on DIY Electric Car? 3D printed covers used to connect on top. I know you said you wanted to avoid that, but might be food for thought and he shared his files.
https://www.diyelectriccar.com/threads/ ... st-1126800
I forget if you were planning to mount under the rear bench seat or under the bus somewhere. You should have the original VW mounting holes for minibus seats in the floor and the seat belt mounts on the angled walled behind that. Thatβs what I used as the basis for a frame for my box. Canβt remember what level of detail about this I shared in my build thread, but I can dig out photos if itβs useful.
Yeah I have the bench seat mounting brackets and am confident I can find multiple ways of attaching any battery box to the van itself.ianlighting wrote: βSun Aug 03, 2025 7:12 am I forget if you were planning to mount under the rear bench seat or under the bus somewhere. You should have the original VW mounting holes for minibus seats in the floor and the seat belt mounts on the angled walled behind that. Thatβs what I used as the basis for a frame for my box. Canβt remember what level of detail about this I shared in my build thread, but I can dig out photos if itβs useful.
