DrJeff wrote: ↑Wed Oct 30, 2019 3:04 amWhen connected to the Proximity line on the controller card, I'm getting +9-12V which is consistent with the EV Connected Ready signal. When I disconnect from the Gen2V3 card (so EVSE connected to nothing I get +12V - no square wave.
As you say those are states A and B and are correct (see image below). Can you also confirm that you get a 1kHz pilot signal with a swing +6V / -12V during charging? Also verify the duty cycle during charging is 66%?
DrJeff wrote: ↑Wed Oct 30, 2019 3:04 amTomorrow I'm going to check the consistency between the GND connections in the garage (I saw a slight difference when measuring yesterday which used a GND from a separate line. All the lines are all feed from the same sub-panel.
I'd recommend using a single car battery to power the BMS and charger. I know this seems like a none issue but the two things I can see that are different in your setup are power supply and 40A single phase
Posted: Thu Oct 31, 2019 6:52 pm
by Rx7FD
I haven't been able to get me tesla gen 2 charger working. I've set the ac current to 5amps, single phase, and termination / dc voltage to 380v. The pack voltage is 340v. When i plug in my j1772 charger, the 3 modules light up and I hear a click, but then a couple seconds later, there is another click and the 3 modules no longer light up. The j1772 charger says it is charging, but no current flows at all. Any ideas on what it could be? Faulty charger?
Posted: Sun Nov 03, 2019 3:10 am
by DrJeff
PROGRESS!!! 2/3, but still better
Thanks guys for the help - finally some progress that points towards a cause !!!
I replaced both PSUs (feeding the 12v/GND for the Charger AND 12v/GND to the Contactors controller) with a single car battery, feed through a switch and a 15A fuse. This allows 2 out of 3 modules to charge (any two modules concurrently charging, but not three). So the charger must be doing some kind of check (current leakage? power availability?) that if not passed prevents the requested charging from initiating. As additional modules are requested either the sensitivity of the test is increased or more likely whatever 'error' the charger is testing for passes a threshold. It could be that swapping from PSU to Car Battery made the difference or just messing with the cables and connections was sufficient.
The odd need for a ground connection between the charger/HVJB cases (grounded to the EVSE) and the GND from the car battery is still necessary for the Gen2V3 card to be able to tell if the EVSE button is pressed, connected, or unconnected. When that ground is missing - the Gen2V3 card oscillates from Pressed to Connected. I suspect that the GND connection from the EVSE is connected to the Model S grounds just after the charge port. So while this looks like an odd ground connection in my setup, it is normal for the Model S (EVSE ground connects to car's body ground rather than to the HVJB case).
Also, I have a laptop with USB connections to the Gen2V3 charger card, and also to my Battery Contactors controller. The 2/3 charging symptom occurred whether or not the laptop was also plugged into 120v power (i.e. battery vs wall plug).
So some things to follow up on next...
1. Further cleaning up / increasing cable size on the 12v lines.
Posted: Sun Nov 03, 2019 1:58 pm
Correctly grounding the charger case, 12V ground and EVSE/AC ground to the same point is curcial for this all to work.
All EVSE signals are ground referenced, also the modulels have leakage detections and earthing checks.
Posted: Sun Nov 03, 2019 2:04 pm
by Kevin Sharpe
DrJeff wrote: ↑Sun Nov 03, 2019 3:10 am
That is good news
Does your EVSE have the ability to generate a pilot signal below 40A? Some have configuration switches for installations that can't support that much current. Would be interesting to know whether the system behaves the same when connected to 30A EVSE.
Posted: Sun Nov 03, 2019 2:06 pm
by Kevin Sharpe
tom91 wrote: ↑Sun Nov 03, 2019 1:58 pm
Yeah, thats critical
Do we have a way of detecting the Tesla power module firmware version or board revision via CAN?
Posted: Sun Nov 03, 2019 2:09 pm
by Kevin Sharpe
Rx7FD wrote: ↑Thu Oct 31, 2019 6:52 pm
What happens if you set AC current to 10A? 5A is below the J1772 minimum threshold and you might be hitting a restriction set in the Tesla firmware.
Posted: Sun Nov 03, 2019 2:12 pm
by Kevin Sharpe
Roadstercycle wrote: ↑Thu Oct 24, 2019 7:17 pm
Are we still rolling the dice on buying a Gen 2 charger and crossing our fingers it works? I'm just about at that point and I'm not overly thrilled with running an ELCON charger.
Damien has two controller boards for me and i'll try to spend some time testing the chargers that we have next week.
Posted: Sun Nov 03, 2019 2:37 pm
Some good news on board supply. I have now acquired a much more reliable pcb manufacturer here in Ireland and boards will be in stock for immediate dispatch. No more silly delays and boards are being built on an automated smd line so quality is much improved.
Posted: Sun Nov 03, 2019 8:04 pm
by DrJeff
SUCCESS!! All 3 modules Charging.
Some additional changes this morning - now all 3 modules are charging...
1. Created a 'ground bar' to which all the GNDs connect (EVSE, HVJB Case, Charger Case, Battery Mgt System [Contactors], Charger inputs]
2. Wired the EVSE ground directly to the ground bar (not to the HVJB case)
3. Cleaned up the connections from the 12V car battery to the Charger controller
A few little things to follow up on...
1. The Gen2V3 controller is still oscillating between button pressed/connected, but charging still works? (I guess it catches a connected state). This may say something about the ground connection between the charger controller card and the charger.
YouTube video here
Posted: Sun Nov 03, 2019 8:26 pm
So, all along it was the mess of your testing setup?
Posted: Sun Nov 03, 2019 9:14 pm
by Kevin Sharpe
DrJeff wrote: ↑Sun Nov 03, 2019 8:04 pm
Congratulations
Posted: Sun Nov 03, 2019 9:55 pm
by Kevin Sharpe
tom91 wrote: ↑Sun Nov 03, 2019 8:26 pm
That's a bit harsh... I can't find anything in the Zero EV user guide about the importance of the charger grounding scheme
Clearly we need to improve our documentation... maybe a charger Wiki would be helpful?
Posted: Sun Nov 03, 2019 11:30 pm
by joromy
I have solved the missing ground on the board by soldering a small wire from one of the ground screw holes to ground on the board.
On the original Tesla board, all screw holes are ground.
But I guess this is fixed in ver. 4 boards
That is good news
Unfortunately, there's no config with my EVSE, it's 40amp or nothing.
Posted: Mon Nov 04, 2019 12:33 am
by DrJeff
Yep, sure looks like it - one of the downsides of learning as you go. Of course trying to 'debug' something like this is a bit of a crap shoot... is it the charger version (couldn't get a clear steer on whether anyone else had my version working), potential firmware differences, singlephase/type1 potential issues, etc.
But in the process I've learned a lot. I understand the charger code in detail, got to test my battery control module many times, I understanding the charging process. All good because that's what I set out to do building the TesLorean - i.e. learn a lot. Now that I can charge the battery I can go on to testing the drive unit, PTC heater, coolant heater, AC, etc.
What has been great is the support and ideas from the forum.
Jeff
Posted: Mon Nov 04, 2019 12:53 am
by Kevin Sharpe
joromy wrote: ↑Sun Nov 03, 2019 11:30 pm
I don't understand... are you saying that the open source PCB is missing some ground connections that are present on the original Tesla board?
I don't see any bug reports on Damien's github so unless he's a mind reader I suspect all versions of the board are the same.
Posted: Mon Nov 04, 2019 7:44 am
by joromy
Kevin Sharpe wrote: ↑Mon Nov 04, 2019 12:53 am
The original Telsla board has ground in all screw holes. That is normal on most boards with a metal casing.
I've opened an issue on github (here) so that Damien is aware and can implement a change or ignore as he wishes.
Posted: Mon Nov 04, 2019 1:38 pm
Firstly I'm delighted Jeff has his charger up and running. We spent a lot of time going back and forth as to what would be causing the problem.
On the subject of grounding. I have mentioned this multiple times on multiple platforms. The Tesla chargers are very sensitive to grounding. The case MUST be connected to vehicle 12v ground AND evse earth/ground when charging. Otherwise problems arise. The open source logic boards do not implement ground on the screw holes. Yes I do know that Tesla do. My reasoning is born of many long days and nights spent chasing ground loops and emi. I have 2 Gen 2 chargers in 2 of my cars charging almost daily with no problems. Is this exhaustive proof of a working design? No, of course not. If people feel this is necessary then please by all means download the design files, make the modification, make some boards , do some testing and report back.
Posted: Mon Nov 04, 2019 2:04 pm
True, at Zero-EV having the three grounds (AC inlet (EVSE), Charger Case and 12V ground) properly connected works every time.
Anytime the chargers are behaving weirdly checking grounds should be a first checking point. We usually bolt a ground strap to the case of the chargers and back to car/vehicle body so we do not have to rely on the bolting interface.
Posted: Mon Nov 04, 2019 2:51 pm
by joromy
Jack Bauer wrote: ↑Mon Nov 04, 2019 1:38 pm
I just want to make the product better....
Having ground holes and ground plane in the bord is good practice.
If this gives you more ground loops and EMI, then everything I have learned about this is wrong.
Have you tried with ground in the screw holes, and that gave you problems?
Beavis: Heh, heh, heh… He said screw holes....
Butt-Head: Uh-huh-huh, uh-huh-huh…
Thank you Kevin, that will help a lot in the near future.
et0 wrote: ↑Sun Oct 13, 2019 8:10 pmDoes anyone know what they weigh?
~16kg
Smuggling one back from the US worked out, thanks Kevin.
I got a -G slave, no obvious damage. Rev 4 charger board populated today, just waiting for the fancy 24 pin connector to arrive. I'll try to fire the board up and load the firmware in the meantime.
Posted: Sun Nov 10, 2019 8:20 pm
by joromy
Yes i did one more mod. That is rather important.
I connected the COM on the ULN open collector driver to 12V all time.
This will return the relay EMF current back to the snubber diode.
If 12V power to charger is shut down, you could also get sneak path to ground, and contactors would energize!
