Simp BMS
joromy
Re: Simp BMS
Post by joromy »
Bryson wrote: Wed Jun 03, 2020 7:05 pm Maybe the better way is SOC * Ah setting * #cells in series * voltage at 50% SOC (interpolated from whatever you chose your SOC settings to be)
That is a good idea, or maybe only use the SOC, shouldn't that be linear to the battery kWh?
Map 0-100% SOC to 0-60kWh
joromy
Re: Simp BMS
Post by joromy »
tom91 wrote: Wed Jun 03, 2020 6:52 pm AmpSecond to Amp Hour :D
I'm a little less stupid now. :?
Bryson
Re: Simp BMS
Post by Bryson »
Yes but battery kWh is calculated from the variables I posted above :)
Has thanked: 328 times
Been thanked: 847 times
Re: Simp BMS
Working on a new add-on, hint below:
SimpBMS CP test.JPG (19.89 KiB) Viewed 10637 times
Also updated the manual, got a section with coming updates with more hints. https://github.com/tomdebree/SimpBMS/bl ... 0V0.22.pdf
mdrobnak
Re: Simp BMS
Post by mdrobnak »
Looks like J1772 support to me...
Bryson
Re: Simp BMS
Post by Bryson »
Oh baby. Is this fast charging in the making?!
mdrobnak
Re: Simp BMS
Post by mdrobnak »
Oh, that would be even better!
Re: Simp BMS
Bryson wrote: Wed Jun 03, 2020 10:33 pm Oh baby. Is this fast charging in the making?!
Nope, CP is for AC charging. No fast charging support planned due to hardware limits.
mdrobnak wrote: Wed Jun 03, 2020 8:37 pm Looks like J1772 support to me...
Yes Type 1 (J1772) and Type 2 current limiting for the chargers so the EVSE remains happy. It will require a small external circuit to condition signals.
joromy
Re: Simp BMS
Post by joromy »
I have Simp BMS and 14 Tesla model S batteries, but two of them are much higher voltage.
Is there a way to discharge (bleed) only these (6+6 cells)?
I would like to bleed them for long time instead of dissemble the whole pack.
I could probably do the changes in software, but need some hint :)
Have tried to use the standard balancing feature from 3.8V and up, this is discharging all cells except the low cell.
I "feel" that discharging only the two batteries all time, would be better...?
Re: Simp BMS
Balancing happens above the threshold voltage IF ANY cell is above the lowest cell voltage + the balancing hysteresis.
It also mentions it in the debug when balancing is going on.
So yes if you set the BMS into the mode where it is allowed to balance it will do it.
joromy
Re: Simp BMS
Post by joromy »
So I could set the threshold voltage very low, like 3.2V, and it will balance all time.
Is it a bad idea?
I think the two high batteries will never get down to average, if I just balance at the top.
They may be 5-10Ah higher. That will take months.
SciroccoEV
Been thanked: 16 times
Re: Simp BMS
Post by SciroccoEV »
joromy wrote: Sun Jun 21, 2020 1:21 pm I think the two high batteries will never get down to average, if I just balance at the top.
Just manually draw those two modules down to similar terminal voltage to the others.
Bryson
Re: Simp BMS
Post by Bryson »
Charge the 12 low ones if your charger can support the lower voltage?
joromy
Re: Simp BMS
Post by joromy »
As I said: "I would like to bleed them for long time instead of dissemble the whole pack."
I just want to know If it's not good for batteries to balance at the hole voltage range?
I will use a hole weekend, maybe more (because I'm slow) to dissemble the pack.
It's built up in 4 layer, tons of connection and coolant pipes.
viewtopic.php?f=16&t=226
celeron55
Has thanked: 39 times
Been thanked: 136 times
Re: Simp BMS
Post by celeron55 »
Set the top balance voltage to whatever the level of the lowest cell is, and then just go do something else for probably many weeks if it's a lot off. This will work with any top balancing BMS.
langoo
Re: Simp BMS
Post by langoo »
tom91 wrote: Thu Jun 04, 2020 8:28 am
Any idea on when this function/module would be able to buy?
Robin Guldmyr
MR Electronics AB
Re: Simp BMS
langoo wrote: Mon Jul 13, 2020 9:27 pm Any idea on when this function/module would be able to buy?
First batch is being produced right now, so hopefully next month.
Been thanked: 411 times
Re: Simp BMS
Tom91
Can you tell me what happens with my Volt BMS?
I have 96s Volt cells, use original Volt BMS. I connected CAN cables and current sensor. It still shows -3A at 0 and i havent put it on the main cable.
I set max cell limit at 4.05V per cell.
Now if i connect charger and charge up to some 392Vdc charger still pushes 4A into cells when they are over 4V. I havent applied charger disconnect pin yet and i use my own CAN string source since i wanted to see what happens.
Now when i charged up to some 4.08V BMS throws ERROR and doesnt show any SOC, but shows Low and High cells in order of 3.889V and 4.085V.
I am not sure that is a good value because if i measure cells directly they are in 4.06V to 4.08V range. Is it possible that cells would show such discrepancy because of balancing?
When i left them to lay off for a day or so they got to 3.895V to 3.980V which is fime for me.
Tom could you maybe change "BALANCING" in the display menu so that it would show instead of error? Or would that be actual error?
Re: Simp BMS
Arber, without logs I cannot tell you what is going on.
Also are you running the charger not via the SimpBMS, so no idea what you mean by still pushing 4A.
langoo
Re: Simp BMS
Post by langoo »
tom91 wrote: Mon Jul 13, 2020 9:44 pm
Any preview of the design and wiring between SimpBMS -> Module -> Type-2 socket?
Price idea?
Robin Guldmyr
MR Electronics AB
Re: Simp BMS
tom91 wrote: Tue Jul 14, 2020 8:10 am Arber, without logs I cannot tell you what is going on.
Yes, well i wanted to see what happens with BMS outputs if i exceed the cell values. So i command the charger separately for now. I didnt expect error msg though. I will make som logs then...
Re: Simp BMS
langoo wrote: Tue Jul 14, 2020 9:16 am
Price idea?
viewtopic.php?f=13&t=815
All in this topic, will finalise the testing and then publish the wiring info.
OutlandishPanda
Re: Simp BMS
Post by OutlandishPanda »
Tom, have you any plans to port SimpBMS to Teensy 4? I need the extra memory and CAN ports. I've tried myself but T4 (I think) uses a modified FlexCAN_T4 library and I quickly got out of my depth... I'll keep trying though.
BTW, your charger interface looks great - I'm sure will be very popular. Thanks.
Re: Simp BMS
OutlandishPanda wrote: Sun Jul 19, 2020 5:14 am Tom, have you any plans to port SimpBMS to Teensy 4? I need the extra memory and CAN ports. I've tried myself but T4 (I think) uses a modified FlexCAN_T4 library and I quickly got out of my depth... I'll keep trying though.
Yes that is the idea, however it is one of many things I am working on so cannot promise any time frames.
Johaljaswant
Re: Simp BMS
Post by Johaljaswant »
Do SimpBMS require always 12 V supply to save any changes.?
