MattsAwesomeStuff wrote: ↑Mon Mar 30, 2026 3:45 am
Generally, compressing quickly is desirable, so that when you hit a bump, the tires can bounce upwards without much stopping them, while the cab stays at the same height. In that way, you won't feel the bump. It eventually needs to reset, but you want it resetting slower than it compressed, spread out over time, so you don't feel the impact. If it bounced back just as hard, it wouldn't feel like you had any suspension.
The goal of the shock is to keep the tire in contact with the ground, aka in control. Too stiff and the tire skips, too soft and the tire or chassis bounces. The steadier the downward force on the tire the more consistent the grip is mid corner.
Spring frequency (spring strength) drives the recovery timing. Wheelbase, spring frequency front vs. rear (each driven by spring strength), and vehicle speed drive the timing the rear recovers vs the front. This is why some vehicles feel great at certain speeds.
Shocks control the springs.
There are all sorts of damping techniques used in shocks. Sometimes they are used to mask other issues.
Re: Bunky the eBug: A 30 Day EV Conversion
Posted: Mon Mar 30, 2026 6:54 pm
by Ev8
Tell us more about the high voltage charger? Would like to up my voltage to gain some power
Posted: Mon Mar 30, 2026 7:27 pm
by Gregski
Ev8 wrote: ↑Mon Mar 30, 2026 6:54 pm
MoonUnit wrote: ↑Mon Mar 30, 2026 3:28 pmJust be aware that having lots of weight upfront makes the steering really heavy. I've tested it with 75Kg, and that made a very big difference. It was just about acceptable, but testing with with 96kg (8 x VDA355 modules) was really not.
*gulp*
Mine had 250 kg in the front.
I truly wonder how it drove, and will never know, I'm not putting 500kg of lead acid back in it.
Posted: Sun Apr 05, 2026 3:44 am
by Gregski
5th weekend of the build was spent on mounting the battery pack, eight BMW 530e hybrid modules
here is the general idea (four sticks across, and eight modules up and down, sardines style)
so we make the mounting brackets to take advantage of the fuel tank mounting points
sometimes you have to spend time doing nonsense like this
Posted: Sun Apr 05, 2026 3:49 am
by Gregski
this C channel was notched so that the mounting tabs would sit in it flush
drill baby drill
I plan to weld these types of nuts under the C channel
and fingers crossed maybe we'll finally get to use the stock OEM fancy BMW hardware, but at 85mm they seem a tad short
Posted: Sun Apr 05, 2026 4:01 am
by Gregski
tomorrow I hope to handle the top row, notice how it has a slightly different pitch
Posted: Sun Apr 05, 2026 7:55 am
by Ghia66
Gregski wrote: ↑Sun Apr 05, 2026 3:44 am
Tapping out those old threads really pays dividends!
Posted: Tue Apr 07, 2026 3:25 am
by Gregski
so here is the bottom shelf with all four modules bolted down using the 85mm stock BMW M6 bolts, when I feel underneath with my finger the bolts are just about even with the nuts, I wish they protruded out about 5 M&Ms
Posted: Tue Apr 07, 2026 3:29 am
by Gregski
progress not perfection, here I was working on the mounts for the upper bracket for the bottom shelf (huh ?)
and the lower bracket for the top shelf
pretty happy that these two siamese twins won't need to be welded together after all and can be removed individually
Posted: Tue Apr 07, 2026 3:30 am
by Gregski
so the bottom shelf is done and I started on the top one
looks like the modules will clear the bracket mounting bolts, so happy
Posted: Fri Apr 10, 2026 4:04 am
by Gregski
here I am welding on the studs for the top battery shelf bracket
and welding on the backing nuts for the battery bolts
also welded the backing nuts to the bottom bracket of the top shelf
Posted: Fri Apr 10, 2026 4:14 am
by Gregski
and the battery pack is in, I even started farting around with the high voltage connections a bit
Posted: Fri Apr 10, 2026 4:17 am
by Gregski
here I am planning the sBox aka contactor box install
Posted: Fri Apr 10, 2026 7:24 am
by Ghia66
So tidy! Looks like it was meant to be from factory!
Posted: Fri Apr 10, 2026 7:38 am
I would suggest you review the specs of all the components in the Sbox before utilizing them with 8 modules instead of 6.
Posted: Fri Apr 10, 2026 9:09 am
by Alibro
Gregski wrote: ↑Fri Apr 10, 2026 4:04 am
What was you reason for not using rivnuts? I used them in my battery box and they were very quick and easy.
Posted: Fri Apr 10, 2026 10:43 am
by Gregski
Alibro wrote: ↑Fri Apr 10, 2026 9:09 am
all my drill bits are standard not metric, and for the M6 rivnuts you need a 9mm drill bit, so when I ordered all the stuff, the rivnuts showed up but the drill bit did not till I was almost done, but mostly it's because I had horrible luck installing them, so I think it's mostly me
Posted: Fri Apr 10, 2026 10:59 am
by Gregski
tom91 wrote: ↑Fri Apr 10, 2026 7:38 am
well Donkey Kong I thought the contactors were rated for 600 volts, but looks like only 500, in my defense the plan was to start off with six modules and if decent top speed was not achieved then expand to the additional ones, so I may be able to go to seven modules but not eight, unless I upgrade them orange cubes, good looking out Tom, you passed the test (wink, wink)
Could someone please help me with this BGR30TQY resistor voltage specs and translate this table for me to fork lift terms?
Posted: Fri Apr 10, 2026 1:01 pm
Resistor will be fine. Have a look at precharge relay.
I would in all fairness be most worried about the OEM BMW electronics, they likely will have an overvoltage limit in them. Probally around that of the contactor voltage.
Posted: Fri Apr 10, 2026 2:06 pm
by Gregski
tom91 wrote: ↑Fri Apr 10, 2026 1:01 pm
Ah yup the AECN 11012 precharge relay in the 2nd Gen aka 12 kWh BMW battery pack sBox can only handle 400 volts
Posted: Fri Apr 10, 2026 3:11 pm
by Alibro
I'm scared enough being around 400V but the thought of 600V is just NO!
You're a braver man than me.
Posted: Fri Apr 10, 2026 3:32 pm
by Ghia66
How about using the BMW SP44 HV Battery (G05) Sbox?
Posted: Fri Apr 10, 2026 4:30 pm
Ghia66 wrote: ↑Fri Apr 10, 2026 3:32 pm
Same architecture so same issue.
Posted: Sat Apr 11, 2026 4:19 pm
by Gregski
the Greg almost rushes to finish installing the battery pack so he doesn't almost loose the shop
