Page 5 of 7
Re: Unlocking the power/torque of Prius gen 3 drive train?
Posted: Mon Jan 19, 2026 6:58 pm
Ghia66 wrote: Mon Jan 19, 2026 3:44 pm It works! Thanks Tom you are a genius!
As in it drive again. Okay will add this change to my ever growing December update.
It still does not change the speed limit :)
Can you do the following, log the same params as you have now but with the wheels in the air. Car very secure ofcourse as you will be pushing the motor over 7000 rpm.
Posted: Mon Jan 19, 2026 7:21 pm
by Ghia66
Thanks Tom.
Ok will do a wheels in the air test.
I am also going to do a road speed test on an open road to be sure, to be sure!
Could you please suggest a parameter change to get some region back?
Cheers Les
Posted: Mon Jan 19, 2026 7:45 pm
Ghia66 wrote: Mon Jan 19, 2026 6:11 pm I have very little/none regen! Lucky I fitted 4 pot Wilwood brakes!
So there maybe a limit somewhere. can you please provide a log a longer one showing regen. Or a graph of potnom showing if it does reach the -15 as per setting.
Posted: Mon Jan 19, 2026 8:10 pm
by Ghia66
Thanks, will do.
Am having trouble finding out how to record longer logs… I used to before 🙁
Posted: Tue Jan 20, 2026 4:17 pm
by Ghia66
So went for a short fun drive before getting the wheels in the air for a spin test.
Posted: Tue Jan 20, 2026 6:17 pm
So there is regen happening.
Need to see if Potnom gets to the -15. Looks like your torque gets to 350ish as it lines up with UDC on your plot. So from this it seems okay as potnom -100 to 100 gets scaled to torque -3500 to 3500, or in your case as its flipped the signs flip.
You seem to be getting to -10 to -15 potnom as per your setting. I would bump your value for regenmax, this is for throttle regen and regenBrake for your braking regen. Just double them if you feel its currently way to little.
Posted: Tue Jan 20, 2026 8:08 pm
by Ghia66
Thanks Tom, will do.
At present doesn’t feel like any regen.
Are these values ok to use to plot for the wheels in the air test run?
Posted: Tue Jan 20, 2026 8:45 pm
Should be okay.
Please plot on the left: Potnom + UDC + IDC
Plot on the right: Speed
Thank you
Posted: Tue Jan 20, 2026 8:49 pm
by Ghia66
Thanks Tom, will do…just a newbie question how do you plot left and right?
Posted: Tue Jan 20, 2026 9:06 pm
when selecting spot values to plot using the L and R tick box
https://openinverter.org/wiki/File:Spot_values.png
Posted: Tue Jan 20, 2026 9:19 pm
by Ghia66
Posted: Wed Jan 21, 2026 11:00 am
by Ghia66
Well it spins faster in the air!
Used the handbrake to slow it down at the end.
Didn’t adjust regen.
Posted: Wed Jan 21, 2026 11:03 am
please confirm which value is which so I am not left guessing.
Posted: Wed Jan 21, 2026 11:19 am
by Ghia66
Sorry Tom I must of cut off the screen shot.
I selected L UDC, IDC & Potnom and R Speed
Posted: Wed Jan 21, 2026 11:33 am
by Ghia66
Ah, this is better!
Posted: Wed Jan 21, 2026 1:18 pm
by Ghia66
In the interest of the Gen 3 Prius community would it be worthwhile to do the same test run in reverse? ( my reverse… Greg’s drive)
Posted: Wed Jan 21, 2026 4:48 pm
by Ghia66
Red UCD
blue IDC
orange Speed
purple Potnom
Posted: Wed Jan 21, 2026 6:41 pm
Ghia66 wrote: Wed Jan 21, 2026 1:18 pm In the interest of the Gen 3 Prius community would it be worthwhile to do the same test run in reverse? ( my reverse… Greg’s drive)
Yes please.
Also wierdly here you get no regen. Also this could be related to "revRegen": 0
Posted: Wed Jan 21, 2026 7:09 pm
by Ghia66
Thanks Tom, will give it a spin in reverse tomorrow.
What do you suggest to change re regen?
Posted: Wed Jan 21, 2026 7:57 pm
set it to -15 like the maxregen
Posted: Wed Jan 21, 2026 8:58 pm
by Ghia66
Thanks Tom, will try that after the stationary spin.
Posted: Thu Jan 22, 2026 12:01 pm
by Ghia66
This is my reverse (Greg’s drive) air spin.
I then changed revregen from off! to on. Left regenmax at -15
The Prius Gen 3 sure likes to rev!
Regen worked well to slow the motor. 🙂
Posted: Thu Jan 22, 2026 12:06 pm
by Ghia66
marcexec wrote: Sat Nov 22, 2025 3:14 pm Not suggesting to test it on the road, but could the "internal" limit only apply for reverse for some reason?
Probaly even too dangerous with wheels off the ground, though I probably hit 150+ with the motorbike wheel at Dublin Maker when some cheeky kid took it out of reverse :D
Wheels in the air…drive and reverse!
Posted: Thu Jan 22, 2026 2:55 pm
by marcexec
Ghia66 wrote: Thu Jan 22, 2026 12:06 pm Wheels in the air…drive and reverse!
Posted: Thu Jan 22, 2026 3:11 pm
Okay so we can confirm your motor is running in reverse which is fine. Toyota do not limit in reverse it appears.
Both go close to 13K reported.
So there must be a current or power limit you are hitting a certain speed. Question is if its related to requested direction not too sure how to easily plot the driving in reverse and getting the 8K speed.
Id say when you get some time can you get another log and graph doing a run to "top speed" if its safely possible.
Left Potnom + IDC + UDC and right speed. Want to see if we derate potnom based on current limit for example, not sure if we rulled that out before.
