We’ve got 86k+ posts plus the wiki, which is awesome… but it also means finding one specific pinout / fix / scope screenshot from a 30-page thread can feel like archaeology. The built-in search often finds threads, not the exact answer with references, so the same questions naturally loop around again.
I’m wondering if it’s worth exploring an AI-assisted search tool (RAG / retrieval-augmented generation). Not a “bot that answers everything”, and definitely not replacing the forum. More like a grounded technical librarian that can:
- search by meaning + keywords (part numbers, params, error codes),
- quote the most relevant snippets,
- link directly to the source posts/wiki pages (so you can verify in one click).
Query:
"Resolver wiring colors"
Top sources:
Forum: "Resolver wiring/pinout for <motor/inverter>" (link)
Forum: "Common resolver wiring mistakes + how to identify pairs" (link)
Answer (source-grounded):
Color codes vary a lot between harnesses, so don't trust colors alone.
Use the method described in the linked posts to identify:
Excitation pair (REF)
SIN pair
COS pair
Then verify with the simple measurements the posts recommend (scope/meter checks) before powering anything.
Links:
https://.../viewtopic.php?t=
Query:
"Pinout of connector J7 on board rev 3.2"
Result:
No exact source found that explicitly documents "J7 rev 3.2" pinout.
Closest matches:
Similar board revision thread with photos (link)
Earlier revision pinout (may differ) (link)
Note:
Tool refuses to guess without a cited source. It will only summarize/quote what it can actually find.
That said, I think it could be done with minimal ongoing cost and without adding load to the forum (e.g., using exports rather than scraping, and keeping any indexing off-site). Details later if there’s appetite.
Questions:
- Would a tool like this be useful to you, or is current search good enough?
- If useful, what would you want it to do first? (e.g. “find the right thread”, “summarize long threads”, “bridge wiki+forum”, etc.)
- Any strong objections/concerns to consider early? (privacy, accuracy, server load, community impact)
Also worth discussing the philosophical/pscychological aspects: could this reduce healthy forum participation? Could it adversely affect paid support dynamics which Openinverter team relies upon to cover costs? Any other ideas how this could be "good on paper" but with possibly ill effects?
I’m not pushing an agenda here, just starting a conversation. I’ve got enough projects already, but if there’s real interest, I could contribute time later.
