Leaf BMS used with other cells
2010RELEAF
Does the leaf bms keep track of battery capacity. If my battery chemistry and pack voltage is the same as factory will it be able to do a 100kWh instead of the 24kWh it came with?
- ianlighting
- Has thanked: 258 times
- Been thanked: 189 times
Re: Leaf BMS used with other cells
I think you’ll find the BMS is programmed to match the physical capacity. In my build, at one point, I had a 40kWh BMS with 60kWh battery. It meant it displayed 0% battery when it still had 20kWh more available.2010RELEAF wrote: ↑Sun Dec 28, 2025 3:22 am Does the leaf bms keep track of battery capacity. If my battery chemistry and pack voltage is the same as factory will it be able to do a 100kWh instead of the 24kWh it came with?
